I took my rx-v 2600 receiver to the local Yamaha repair center. They say it need a WG078700 DSP CIRCUIT BOARD. They wanted too much to repair it. Is this something that could be installed easily if I purchased the part? Is there an inexpensive place to purchase the board?
The board price won't be cheap. Were they going to replace the board or repair it? It is possible that the component parts are not available from Yamaha and the only option is to replace the board. Other shops may be able to repair the board. What was the original problem that lead them to want to replace the board?
Dan
That does not sound like a DSP issue to me. Can you try an experiment? Set the unit for standard stereo mode (no surround) and see if you can duplicate the problem and report the results here.
Thanks,
Dan
You should be able to set the unit to standard by turning off surround. This will isolate the problem to either the DSP board or the feeder to it.
Dan
Yes, I have done many receivers both Yamaha and others. My contact information is in my Ad here at Fixya. Email is best.
Dan
There is only one authorized repair place in Dallas. They attempted to do a component replacement but that did not work. So they wanted to replace the entire board. That's when things started getting expensive. The problem with the receiver is that the left speaker quits working. If I turn it off and then on, the speaker starts working again but quits shortly after. It is an intermittent problem the repair shop had difficulty finding and isolating.
OK. I will try standard mode (no surround). It may take a couple of days as it is not hooked up right now and with all the wires, it does take some time to get it going. Not sure how to do what you want but will make it happen.
Thanks
You sound like you have done this before. You have phone number that I can use?
Board price is $182.00 by the way. PLus I paid K-O Electronics $75.00 to evaluate the problem.
Thanks for the help
