Garmin nuvi 255W GPS Receiver Logo
Posted on Mar 25, 2010
Nuvi 255 stopped working
Hi, When I turn on my GPS Nuvi 255 now, I get the Garmin name to display and then nothing - it goes completely blank .The last time I could get past this, the battery light showed lots of power - any suggestions?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
448
Points
Same thing here. Does anybody have any answers?????
2helpful
2answers
When i turn on the GPS it is just stuck on the garmin screen and does nothing else.
Here is just a suggestion , try this and let me know if worked. It needs to be rebooted. Turn off, by holding off button down. Then once it is completely off, then turn it on, BUT when you go to turn it on, keep on button depressed, all the way until it turns on and then some for about 15 seconds, now you just rebooted system. Let me know, mike
Turned on the Garmin nuvi 1200. the Garmin logo comes up, loading maps comes up then it goes blank and begins the cycle again. I have held the power button down nothing. I have touched the bottom right of...
Hi! Please try inserting a paperclip on the reset button. Press hold for atleast 15secs. and this can resolve the problem. Hope this helps and thank you for using FixYa!
2answers
My garmin nuvi 2255w is completely dead. Will not turn on, the screen stays blank. I plugged it into the car plugin and it does nothing. It was working just fine before now.What could be the problem?
My garmin Nuvi (205 I think) just stopped working...blank screen, does nothing? Was working fine a few hours ago. Car plug in lights up when plugged in but still nothing.
Garmin nuvi 255 won't turn anymore
i had same prob about a month ago it sorted it's self out after left on charge for a week
Replace battery garmin 255
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Garmin Nuvi 255 won't charge with the car charger.
You may need to replace the battery.
Black screen displaying only Garmin and a blue triangle
to soft reset & keep data....
Slide power key to on/off, hold it for 8/10 seconds
Update from Garmin, use the web-updater. keep it updated, delete old junk and POIs.
hard reset.
Hold lower corner of screen, while turning on, keep pressing, when "clear all data appears" click yes,
sould resolve the problem
Hope this helps.
Regards.
Nuvi 200 screen is extremely dark
The screen brightness could be turned down or the display itself is defective. Even if it was turned down all the way it should be somewhat visible, so if the display is completely blank, I would suggest that the LCD display has become defective.
- Jim
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
