SOURCE: toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
SOURCE: rerace lines @ top of tv Toshiba 27A33
change the 100/50volts capasistor on vertical section
