This is a typical anti flood activation due to the anti flood device (polystireen float and micro switch) at the base of the washer detecting a water leak / spill. This device puts the washer in pump out mode. Check to see if water at the base is causing the polystireene float to activate the switch. Dry the water and rectify the fault (normally a leaky pipe or pipe clamp) and this should solve the problem.
