Garmin Nuvi 205 can't unlock map. Tech support on Garmin is useless. I followed all the directions to the letter, and still end up with a $150 paperweight.
I copied the unlock code into a "gmapprom.unl" text file and replaced into the Garmin folder on the device per instructions. Didn't work. There is no factory reset, that I am aware of, on this device. The device refuses to work with the maps locked. My Garmin account shows the map update as installed and unlocked correctly. But my eyes see a locked down, useless device.
First, check to make sure the map file is there. The file name is gmapprom.img. It's located in the Garmin directory. It should be 1GB in size. To do this you need to connect the Nuvi to a PC with a USB cable.
Next, please tell me what year of map you have on your unit, 2009, 2010, etc.
Them, email me your units internal serial number. Its a 10 digit number (not the number on the outside). The number starts with a "3" and can be found by pressing the tools button, then system and then "about".
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
The GPS device is missing it's unlock code
The maps on the GPS device have been disabled
To
determine the cause of the message, touch the screen until the message
"No Detailed Maps Found That Support Routing" disappears.
If
you see a "Can't Unlock Maps" message following this error, remove any
microSD / SD cards in the device and follow the instructions below for
Retrieving your unlock codes followed by the instructions for Creating
an unlock file
If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
To
retrieve unlock codes you need to have your satnav registered with
garmin. If you haven't already registered it connect the satnav to your
computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces
and click Register your garmin device. Follow the prompts. You'll be
asked to create a username and password. Write them down and keep them
safe. You'll need them anytime you need to update your maps or solve
problems in the future.
The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
Plug your Garmin device into the USB port
Double-Click on My Computer or Computer located on the desktop
Right-Click on the Garmin or nuvi drive
ClickExplore
Double-Click on the Garmin folder
Right-Click in a blank space in this window
Move your mouse over the word New
Select Text Document
Press Enter / Return on your keyboard
Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
Select File
Select Save As
Change the Save As Type to All Files
Type gmapprom.unl in all lower-case letters for the File name
Select Save
Close the Notepad window
Delete the New Text Document file
Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
Open the TextEdit application located in the Applications folder on the Mac HD
Click Format
Select Make Plain Text
Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
If
you have a second maps you may also need to unlock it e.g. if the first
map is USA and second is EUROPE this may also need to be unlocked
Click Explore
Type
the European unlock code that is listed in the Manage Maps section of
your myGarmin account. This will need to be typed in all upper-case
Select File
Select Save As
Type gmapprom1.unl in all lower-case letters for the File name
Select Save
Enabling maps on the GPS device:
Touch the wrench icon on the Where to/View map screen
Touch Settings
Touch Map
Touch Map Info
Select the checkbox next to the maps to be enabled on the device
To
If
an unlock file
To
ClickExplore
Select File
Select Save As
Select Save
Click Format
If
Click Explore
Type
Select File
Select Save As
Select Save
Touch Settings
Touch Map
Touch Map Info
To
If
an unlock file
To
ClickExplore
Select File
Select Save As
Select Save
Click Format
If
Click Explore
Type
Select File
Select Save As
Select Save
Touch Settings
Touch Map
Touch Map Info
The GPS
The maps
To determine the cause of the message, touch the screen until the message
If you see
Retrieving your unlock codes followed by the instructions for Creating an
unlock file
If you do
Enabling maps on the GPS device at the bottom of this solution
To retrieve your unlock codes you must first register your satnav if
you haven’t already done so.
To registe;
·Click on “Register Your Garmin
Product” and follow the prompts
You’ll be asked to create a username and password. Write them down
and keep them safe as you’ll need them anytime you want to update your maps. Retrieving your unlock codes:
To
If
an unlock file
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your garmin device. Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
ClickExplore
Select File
Select Save As
Select Save
Click Format
*nuvi x70 owners with transatlantic mapping will need to follow the Creating an unlock code file instructions above for their U.S. mapping and then create another unlock file for their European maps:
Click Explore
Type
Select File
Select Save As
Select Save
Touch Settings
Touch Map
Touch Map Info
I've been trawling for unanswered questions; this information may
be too late for you (or perhaps it may help you resurrect a useless machine which
you have put away) but it will certainly help others searching for advice with the
same problem.
You have Garmin Lock activated on your nuvi: there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it or you wouldn't be reading this).
2.
Take the unit to the Security Location you chose when activating Garmin
Lock: it will then unlock without the PIN code and you can then either
reset the PIN or disable Garmin Lock. The Security Location should not
be the owner's home address, but many owners ignore this recommendation.
Many owners choose their workplace or a close friend or relatives
address for this purpose.
If neither option works then your unit
is useless unless you send it to Garmin with proof of purchase. Garmin
charge for the service and if your maps are not up to date then it's
really a waste of money as the investment would be better spent on a new
unit with current mapping.
I hope that you manage to either fix
your problem using my advice or at least can decide whether to abandon
the unit and buy another.
I do know a 'workaround' to Garmin's copy-protection for maps you legally are entitled to use, but before that, when a Garmin Nuvi 205 stops working or behaves strangely, there are
two steps you can take yourself to try and get it going again:
