Question about Technics SL-1200 Turntable
Could you tell me where I can get hold of a Technics SL 1200 owners manual. Thankyou
Posted by nikki53 on
wayne walker
  • 779 Answers
Use this link and enter the model number in the search and the manual will be displayed http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
I tried to link to the manual direct - but you have to go through and acceptance before you get to the download
if that does not work - use this link http://www.panasonic.co.uk/html/en_GB/Support/219854/index.html and click on downloads
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Posted on Mar 25, 2010
Owners manual for SL-L3 turntable
Two Speed Direct Drive Fully Automatic Turntable with linear tracking ... Technics SL-L3 / SLL3 owners manual, service manuals and schematics are for ... www.vinylengine.com/library/technics/sl-l3.shtml
hope this will be of help
Feb 02, 2012 | Audio Players & Recorders
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
How do you balance & adjust tonearm after changing stylus
turn the whole weight until arm sits just above platter.hold back of weight and turn front disc to zero. turn whole weight to spec for cartidge fitted,usually around 2.
Nov 21, 2009 | Technics SL-1200MK2 Turntable
User manual Technics DZ-1200 turntables & Pioneer DJXM600 mixer
I found your manuals below:
Technics:
http://www.givemefile.net/manuals/musical_instruments/technics/sl-dz1200.html
Pioneer:
http://www.nodevice.com/user_manual/pioneer/dj_mixer/djm-600.html
Sep 22, 2009 | Technics SL-1210 Turntable
Technics SL-QL15 turntable for the charity shop?
If it still in perfect running condition, An audiophile of LPs should be interested in buying it. I sold my 30 year old Technics SL-1300 mkII for $250
Jul 30, 2009 | Audio Players & Recorders
How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
Mar 25, 2008 | Technics SL-1200MK2 Turntable
Technics SL-1200 Turntable Logo
146 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
