Question about Gateway GT5453E Refurbished AMD Desktop Computer - AMD Athlon 64 X2 4200+ 2.2GHz , 1GB DD
Composite connection on Gateway Desktop
THE PRODUCT IS NOT CORRECT; IT'S WHAT MATCHES THE CLOSEST.
Three years ago I purchaced a Gateway Desktop computer. I don't know the model (sorry, it's not the computer I'm currently on) but it has an area for composite (red/white/yellow) cables and I don't know how to use them. I've tried hooking up my XBOX 360 to them to play it through my monitor but no dice. What are these meant for then? I've never used them. Any help would be greatly appreciated.
V/r,
Don
wayne walker
  • 779 Answers
They are Video and Audio for connecting device together
  • Yellow = Video
  • White = Audio - left channel
  • Red = Audio - right channel
the connectors on a Desktop PC from the graphics card will be an OUTPUT-possibly labelled TV output, so what ever is displayed on your monitor can also be sent to a TV or recorder etc The connectors on the Xbox are also OUTPUT and designed for connection to a device which has the same connection but for INPUT
Your monitor may have composite inputs and allow you to switch to those Some TVs will have those connections as inputs and you would select one of the AV options to see the signal, often a separate button to choose AV input /HDMI / PC etc Some DVD and Video also have these as an INPUT as video cameras often have that type of connection - to record the signal
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Posted on Mar 25, 2010
Testimonial: "Thanks!"
Life expectancy of television
Depending on the type of TV, the longevity can be affected significantly. If your TV is a plasma model, they run very hot and the plasma only lasts about 4-5 years. That is why plasma is no longer being made by any of the major manufacturers. It was state of the art when it came out, but now LED TVs are the standard. They use much less energy, run a lot cooler and last much longer.
Longevity really depends upon the technology used, not always who made it.
May 03, 2017 | Sony BRAVIA Televison & Video
3com 3102 not working
try 192.168.2.1 / 192.168.2.0 / 192.168.0.1
hope it works.
enjoy
Feb 15, 2008 | 3Com NBX 3102 IP Phone
No sound coming out of my speeakers. Speakers hooked up. Note: computer would not boot up two days ago, then began doing so. COuld this be motherboard prob lem?
Hello! please go to this website: http://www.dell.com/support/drivers/us/en/19/Product/vostro-200
Here is a link to reinstall the correct bios firmware http://www.dell.com/support/drivers/us/en/19/DriverDetails/DriverFileFormats/Product/vostro-200?DriverId=R199863&FileId=2731123001&urlProductCode=False
Then choose the correct OS from the drop down and reinstall your sound card drivers. let me know how that goes!
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 26, 2012 | Dell Vostro 200 PC Desktop
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Gateway GT5228 Motherboard Replacement
http://www.fic.com.tw/product/motherboard/AMD/KTBC51G.aspx Seems to be the most consistent answer that I find. Hope it helps.
Jul 27, 2009 | Gateway GT5228 (7156) PC Desktop
Gateway boot problem
This mostly happens when your motherboard is bad or one of the memory modules is bad.
The led light comming on indicates your power pack is ok but a component is failing to start especially when the laptop stops at the first screen stage where the manufacturer names appears.
The steps needed to solve this kind of problem would require technical skills and physical inspection.
If you still have a waranty period then seek a free service repair from an authorized or certified gateway service centre at the nearest centre closest to you.
If your warranty has expired, i still advise taking your Laptop to the closest Gateway service centre.
May 21, 2009 | Gateway MT3705 Notebook
How to correct connection problem for two LaCie Desktop Hard Driv
Here is the support website for the LACIE products.  As far as I knowthis site simply answers questions. Sounds like the hard drives are bad to me.
http://www.lacie.com/support/
Jan 07, 2009 | LaCie Computers & Internet
Finding the DV outlet on my computer....
From what I see you have three "DV" inputs. They are called Firewire to the rest of the world. Also known as IEEE 1394. They are rectangular with a semi rounded end.
Dec 02, 2008 | Gateway GT5220 PC Desktop
LP Turntable
the platter must be able to spin freely without a belt installed as shown in this video
http://www.archive.org/details/Turntable_Belt_Installation
that would be one likely cause presuming you have the correct new belt that is.
Oct 26, 2008 | Panasonic Technics SL-DZ1200 Turntable
Gateway GT5453E Refurbished AMD Desktop Computer - AMD Athlon 64 X2 4200+ 2.2GHz , 1GB DD Logo
119 people viewed this question
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
