Question about Brother MFC-7820N Printer
SCREEN SAYS BACK COVER OPEN.WHERE IS BACK COVER?
Posted by rtbris182 on
Patrick Wolthausen
  • 240 Answers
Hello rtbris182,
The "back cover open" message is usually caused by a paper jam inside the printer.
Follow these steps to rectify the problem.
1. Unplug the power to the printer.
2. Open the back and front cover.
3. Remove the drum and toner, this may be difficult because it may be stuck; don't be afraid to pull hard, you wont break anything.
4. Check for any foreign objects, most likely a peice of paper.
5. Reinstall the drum and toner.
6. Make sure to close the front and back covers.
7. Turn the power back on.
If the message stays after all this, there may be a sensor not working.
Thanks,
Pat
Posted on Mar 25, 2010
Taking cover off nintendo ds lite
Are you talking about the back cover or front cover?
Either way, before starting you are going to need two things: A tri-wing screwdriver and a Philips screwdriver.
To remove the BOTTOM COVER, you must take off the stickers covering the screws and remove the screws. 001e10e1-317e-4bb5-97cd-230a82f77aaf.jpg
Then, carefully pry the back off, revealing the motherboard inside.
To remove the TOP COVER, you must take off the stickers covering the four screws in the corners of the INSIDE top screen. Unscrew them and gently push the inside top screen down until its about half a centimeter apart from it's backside. Then pull the backside off and you have it open.
If you wanted to open the DS completely, like have it in half, you should first open the BOTTOM COVER and remove the motherboard after disconnecting it from everything attached to it. Then follow the steps given for removing the TOP COVER and slide the ribbon and cables sticking through from the TOP to the BOTTOM back to the TOP so that they are not sticking through and won't be damaged when you take the DS apart. Then unscrew the power light and voila! The DS should be separated.
May 31, 2014 | Nintendo DS Lite
The screen says the "back cover is open" and
If you turn the printer off and then back on with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Jan 24, 2011 | Brother DCP-7020 Black and White Copier
Printer quit printing. Screen says fuser cover is open. Where is it located so I can close it?
Your problem: paper is jammed in the back of the printer around/in the fuser.
The Users Manual for your printer is located at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users Manual/UM_DCP_7030_7040_EN_1510.PDF
You'll need Adobe Acrobat Reader (free from www.adobe.com) to view it.
LOCATION:The fuser cover is located in the back - its covered by the panel in the back called
the "back cover" aka "back output tray cover".
2-step fix:
(A) open the back cover - on the back of the printer.
HOW: it flips down
(B) open the fuser cover and remove paper jam
How: Pull the 2 tabs (one left and one right) toward you to open the fuser cover.
(it also flips down to open).
Most of this fix comes from downloading the Users Manual and blowing up page 60 (of 108 pages).
Jan 01, 2011 | Brother DCP-7040 Laser Printer
Screen reads "back cover open" and it is not open. it will not allow us to receive faxes....???
there is possibly a switch actuator that has broken on the cover. check cover for any missing or broken pins on the cover. jaime
Jul 08, 2010 | Brother IntelliFax-2820 Laser Fax
Casio PRO TREK error 'OP EN' Display frozen with the above msg. None of the buttons - except the light - works. Whats wrong .. battery charge shows FULL
The problems is very simple: On the back cover (inside) is a little Cu metal Part. This part is glued to back cover using a poor glue (rubbered glue) and, in time, is moving from original position. You must put back this parts to original positin ( a little hole inside of back cover) and glue using a good glue. When the back cover is mounted , this part must have a ferm contact with two springs from mechanism (sensor for back cover open). If beatwin this springs isn't a electric short (using Cu metal parts) the internal mechanism of watch "see" the back cover is open and show "OPEN" on screen!
Mar 22, 2010 | Casio Watches
What to do when the screen indicates that the back cover is open?where is the back cover of the printer located?
back cover just on back side of the printer. There usually sign showing that you can pull jammed paper from it.
Sep 23, 2009 | Brother HL-2040 Laser Printer
Brother MFC-7420 Fax Scan Copy
Maybe there is broken at the back cover try to check again the back cover,inspect the cover very well .
Nov 09, 2008 | Office Equipment & Supplies
Cleaning the screen cover on my sony big screen
To clean its front screen, you should not open front cover as its complicated procedure. just take off its back cover as its shown in picture and use air-blower to clean dust. Then use soft cotton cloth to clean its screen from internal and 3 bulbs / lenses (CRTs) and job is done.
Need further help, let me know.
Bye.
Sep 13, 2008 | Sony KP-57WV600 57" Rear Projection...
X20
If you open up the battery cover, you should see 6 tiny philips screws to undo, as well as two on the side of the player, opposite the headphone jack, underneath two little gray cover discs. Don't worry about opening up the player, it stays in relatively one piece besides the screws and the case. Once you undo the screws, you should be able to carefully pry open the case down the sides of the player, opening it up will expose you to the backside of the screen cover, as well as the screen itself. Just wipe it all down, and when you're satisfied, pop the cover back together, and throw those screws right back in! Pretty easy! I did have your same problem. This is what I know to do about it.
May 12, 2008 | iRiver X20 MP3 Player
Back Cover Open
I've been researching this problem. It seems to be a common issue with this MFC. Apparently it's not only a known issue, but Brother has no fix for it outside of replacement.
May 09, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-7820N Printer Logo
259 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
