Greetings,
A majority of the time when this happens, it's caused by the hose having a short in it. You'll need to first identify what the source of the short it. To do this, turn the power brush on, and then swivel the hose on both the end before the handle, as well as the end that plugs into the vacuum, can you get the power brush to cut on/off for you from here? If yes, then you'll need to purchase a new hose. You may purchase this hose directly from Sears, however when you buy the hoses through Sears you have to assemble the hose yourself, which is very challenging. An easier way for you to replace the hose, is to purchase a Panasonic canister hose. There are two types of hoses, a 2 wire hose, and a 3 wire hose that fit most Kenmores. When you take the hose out of the canister, look on the part that plugs into the canister, how many prongs do you see here? If 2 then you'll need a 2 wire hose, if 3 then a 3 wire hose.
If you are not able to locate the short in the hose, then you may have a short either in the wand, or the power nozzle neck wire. For the wand, put one foot on your power nozzle while it's running, then pull up and down on the end of the wand that plugs into the canister, as well as the end that the hose plugs into. If you can get the vacuum power brush to cut on / off when you're doing this, this indicates your wand is bad and needs to be replaced. If it doesn't cut on / off, remove the wand and hose from the vacuum completely. Now look where the wand connects into the power nozzle. You should see two electrical prongs on the neck of the power nozzle. Do you see any burns, or black marks on the prong, or the plastic part that it comes out of? You can also test this part by turning the vacuum's neck to the left and to the right as if you were turning the vacuum.
Hopefully this helped you. If you need further help on figuring out which part is bad, please just use the clarification request here on Fixya, and I'll be happy to try and diagnose this further with you.
Thanks,
Chris J.
GoVacuum
Testimonial: "Thanks, Chris! Great advice. Initially at least, I believe the short is at the connection of the wand to the powermate head. "
Hello, Can you please give me the exact model Kenmore that you have so I can look up the parts diagram and figure out what type of neck is being used? The number that is listed here on Fixya is not correct. Sears Kenmore models have a very long model that number that always starts 116. If you can please give me the entire string of numbers here, I'll be happy to send you a blown up parts diagram to try and help you further diagnosis the neck. The model number may be found on the bottom of the canister part of the vacuum. Thank you,
Chris.
Chris,
Since the intermittent short happens only when the wand is held vertically or turned toward the left (power is steady when I swivel the wand all the way to the right), I think the short is in the power nozzel neck wire. I unscrewed the neck of the nozzel and inspected the wiring at both soldered connections; nothing seemed amiss. Is there a way to further take apart the neck so that I could view the upper connection to the wand?
