Question about Nintendo Wii Console
Just added a new wii controller now I have 2. I activated but when I try to use it to play tennis against my husband only his remote works mine wont swing. The cursor is on the second one is red and lloks faded not as strong looking as the cursor for remote 1
Posted by laurahardinn on
Daniel Kozachek
    Sniper:
  • 122 Answers
When you are on the screen where you select number of games, use the second WiiMote to click on the two characters on one of the sides of the screen. that will assign them to the player 2 controller. Hope this helps =)
Posted on Mar 25, 2010
Will not swing when playing tennis on Wii Sports. It was working previously.
if you are using a wii motion plus, try placing it on the ground for about 5 minutes, and if that doesnt work call nintendo.
Dec 08, 2009 | Nintendo Wii Remote Controller
I bought a second remote and i threw the box out with the instructions, anyway i dont know what to do to make it work so that two of us can play tennis etc. only the one original remote works.
Have you tried calibrating the controller? There should be a small button on the controller, i believe its where the batteries are, hold that down while holding down the button on the Wii.
Nov 24, 2009 | Nintendo Wii Fit for Wii
My wii remote works fine when I play with one player, but the first remote will not respond in tennis, baseball or golf when the second remote is added in a two-player game. What can be done to fix this?...
you have to remove the battiers from both of the controlers and put in new ones but they have to be the better ones cuz that's what i had to do to mine and then scyn both of them that should do it if not then you will have to go into the settings of the wii and go to the control screen and form there you can syc one at a time but you have to follow the instruction to the T or it will not work if that dosnt do it then you will have to go into the settings again and reset the wii to its defolt mode that i know will work for your problem
Sep 21, 2009 | Nintendo Wii Console
Wii mote non responsive to movement
my mote isnt respindind to the scencer!
Feb 12, 2009 | Nintendo Wii Console
WII REMOTE
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jan 27, 2009 | Nintendo Wii Console
Second controller doesn't recognize accelerate, reverse works
Try resynchornizing it to your Wii again. If this doesnt not work, you may have a defective Wii Remote. You should consider replacing if synchronizing it does not work.
Jan 04, 2009 | Nintendo Mario Kart (Wii) for Wii
Problems with a Wii game
if you are in the mulitplayer mode and still have trouble adding the remote then try syncing the remote with the wii first by pressing the home button then go into the wii remote settings on the bottom then re-sync each control. Then try going back into mulitplayer mode and try again or while the screen is on when you want to add more players press the '+' button.
Dec 28, 2008 | Video Game Consoles & Games
Nintendo wii problems
Hold the Wii Remote with the button side down. Without using much force, firmly tap the button side of the remote against the palm of your other hand a few times. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard. Check for proper response.
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen.
  • Make sure you are using fresh batteries in the Wii Remote.
  • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
  • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
  • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
  • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
I hope this fixes it for you!
Jul 08, 2008 | Nintendo Wii Console
My wii remote
@ Slivic22
Some games does not use Sensor Bar pointing because they play with motion/accelerometer only. After you select the number of sets on Wii Sports Tennis, there is no Sensor Bar pointing except for Pause menu. That's because you Swing the remote like a racket.
May 24, 2008 | Nintendo Wii Console
Wii remote error
The accelerometers are stuck. Hold the controller so you can smack it on the palm of your free hand. Smack on the palm of your hand with the same force and quickness as you would a fly swatter. This will free the accelorometer. The accelorometer gets locked up when you swing to hard. Also try changing your batteries.
Sep 06, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Aron
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
