Have a trcity bendix washing machine and during a wash it was making a loud baning noise from the drum when spinning . i went to look and there was smoke coming from the back of it and out of drawer . it is less than three years old . am i entilted to a new one .
Re: Have a trcity bendix washing machine and during a...
It sounds as if the bearings have gone or something as serious that needs inspecting.This machine would have the normal 5 year major parts warranty and they would offer a repair but you would pay the call out and labour.Hope this helps.
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
The turning tube's belt or bearing may have problem. If you know how to tighting the drive belt, you may try. If not, maintenance or service persone should to call.
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
You will need to get the bearings replaced. Most noises
from a washing machine occur during the spin cycle. If you hear loud
thumping during the spin, the load of clothes may have become
unbalanced. Stop the washer and redistribute the clothes, then re-start
it. Repeat these steps if necessary.
