Question about Samsung LA40A450 40 in. LCD TV
Check the power board for dommed capacitors and replace them. If this does not fix get back to me.
Posted on Mar 25, 2010
SOURCE: RED LIGHT KEEPS BLINKING..WAS LIKE A POWER SURGE
Surge protectors aren't perfect... If the surge was big enough and long enough then it can cause problems. Most manufacturers have on-board protection as well. That's not perfect either. Often the surge does nothing more than confuse the microprocessor (computer) that controls all aspects of your television. The fact that the red light is blinking means that your set is trying to protect itself. This can happen for one of two reasons. Something in the set has failed. Usually the power supply inside the set possibly also a trouble in the scan section of your set. These are normally a shop repair. The other thing is when the microprocessor is confused it will do nothing further until it's reset. To reset the processor simply unplug the set from the wall and wait 10 minutes. Plug it back in and if it works then happy viewing. If it doesn't then you will need a repair.
If is a failure caused by a failure in the grid that delivers power to your set then you are usually able to file a claim for the repairs. Contact your local power company. explain what happened. If it's their fault then usually they will pay for a repair. I know the PG&E does.
Zashiban
Posted on Jun 23, 2010
Mar 08, 2011 | Sony KV-36FS13 TV
Feb 17, 2011 | Sony KP-43HT20 43" Rear Projection...
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Oct 12, 2009 | Philips Ambilight 2 52 in. Flat-Panel LCD...
Feb 12, 2009 | Philips 42PF9630A 42 in. Plasma Television
Aug 17, 2008 | Sony KV-24FV12 24" TV
Jun 04, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Dec 27, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Jan 21, 2014 | Samsung LA40A450 40 in. LCD TV
Jan 05, 2014 | Samsung LA40A450 40 in. LCD TV
Dec 22, 2013 | Samsung LA40A450 40 in. LCD TV
340 people viewed this question
