LG X-Note LM50 Notebook Logo
Question about LG X-Note LM50 Notebook
Couldn't open the built-in webcam
"NOT FOUND WEBCAM DEVICE, CHECK YOUR PC CAMERA" SHOWN WHENEVER I CLICK THE BUTTON IN MY LG E200, WHAT SHALL I DO?
Posted by lauichiro on
Jose Cada
  • LG Master
  • 3,530 Answers
Try to reinstall you webcam drivers. usually when you purchased the laptop it came with driver disk. look into the driver disk and install your camera software driver
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Mar 25, 2010
How do I access and use my webcam.
from the Advent site
"Many laptops now come with an integrated camera, located above the screen, at its centre. You can usually open the web camera by going to Start and typing 'webcam ' into the search bar.
In the list that appears, there should be a camera or web cam option to select. If you can't find your web camera, follow the steps below:
1. Click the Start button, located at the bottom left of the screen.
2. Open the Control Panel (as shown in red below).
3. Select Hardware and Sound.
4. Open Device Manager and double-click on Imaging Devices. Your webcam should be listed among the imaging devices."
I have asus k53s series and my built in webcam does not appear or shown on devices and printers..but when i use yahoo messanger and skype there's a image view on webcam but it is flip vertically u
Your webcam would be listed under Imaging Devices in the device manager. If it is showing you an image when you use skype or yahoo messenger then it is installed. Go into the webcam software to change the settings on how it is projecting the image.
You have to open the webcam software to activate or start the webcam. There is no button to push or switch to turn on. The webcam software is somewhere in the program list. Click Start/Programs then search for any reference to webcam or camera. Sometimes the webcam might be inside one of the manufacturers folders in the program list so search the folders for it. Some manufacturers have something like Entertainment Experience that will open and show all the entertainment devices such as the dvd drive, webcam, media player, etc. if you see it click it to launch it then click on the webcam or camera icon.
Try using ManyCam
You can always download Manycam and install it. Go to www.google.com and in the search box type: "download.cnet.com" (without the quotes). Click on the link to go to the site. When the site opens look down on the left and you will see a gray area that says Find Software. Type "Manycam" (without the quotes) in the white search area then hit the search mirror. When it brings back your results look for the one that says ManyCam Virtual Webcam. Down load it and install it. Make sure you remove the check box on any junky programs it would like to install. You only want to install ManyCam, no additions whatsoever during the install. ManyCam is totally FREE and easy to use, and you will always know where your webcam software is.
My Webcam Model 156 does not work on my computer. I also don't have a webcam software. what shall I do ?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
When i open acer crystal eye webcam then it is shown that "camera is not installed or camera is occupied by another user".but in the device manager it is shown that camera is installed.can i...
Hi
i would try this
go to start button
then run or type into the box device manager
then scroll down to find imaging devices
click on the webcam un install it
restart the laptop
and hopefully windows will install it correctly on startup
good luck
many thanks
1helpful
2answers
Dell inspire laptop 1564 webcam not working properly. Whenever open the dell webcam center the error showing as below: "please plug in a supported device"
It sounds like the driver does not match the WebCam.
Uninstall the WebCam driver and WebCam
Reboot the laptop and reinstall as required.
Hope that helps.
2helpful
2answers
Webcam on lg w2271tc doen't start. the drivers are from factory cd. i install them but the camera doent start. right after the installation machine needs restart. after restart , still the camera doent...
first install the driver software plug the usb to your pc...
then after that goto device manager click the (!) right click it goto properties and auto detect driver the pc will find the dll of you webcam then when he finds there were pop-up window you see if you see the highlight choose by your pc just click next it is only done. then you will not see again the (!). ok just follow my instruction
1helpful
2answers
Same
If its a dark screen what you can see then you can do one thing "on the cam window under OPTIONS check/uncheck the PREVIEW option" and check if its working.
If it says "no video capture device found" then the drivers you have installed are not fully compatible with VISTA, for this you can do one thing---
1. Remove the previously installed webcam drivers, delete the installation folder from Program Files if its still there, disconnect (unplug) the webcam, reboot the system , Scan the registry using ccleaner (freeware).
2. Install the program you use to access the web cam (eg: amcap etc).
3. Now attach the webcam (be connected to the internet), when the driver installation screen pops up click "Install automatically" it will search for the system files for the drivers or go to the windows update (this works many times) if not found.
Once done & successfully installed the webcam shall work fine now.
47helpful
8answers
Cant turn my built in webcam on??
This is known Webcam issue in DV6000 notebooks. To resolve or narrow down the issue, we have to check few things.
First open Device Manager.
Please follow these steps to open Device Manager:
1. Right Click on 'My Computer' icon on Desktop and choose Properties.
2. The System properties Window opens.
3. Click Hardware tab and then click the Device Manager button.
Expand + Imagining Devices and check if the HP Webcam is listed under it.
If Webcam is not listed there, then you have to contact HP to get the BIOS update.
If it is listed there, right click on it and select Disable. Again right click on it and select Enable.
Now open any applications like Quickplay and check if Webcam is working or not.
Please reply me if that won't resolve the issue, I can provide more work arounds
Top LG Computers & Internet Experts
Marvin
Marvin
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
