boot your computer with windows XP cd. it will install winXP automatically but remember to install windows XP other than the drive where your win7 is. for examp: if your win7 is in C drive, install XP in D drive.
hope you can do.
Not sure what you have done so far. You need to divide your hard drive into two sections. Install XP first on to one section. Then use a program to manage your computer start up, the one I use is called Easy BCD this is a free program and works great. Once you cut your hard drive and install XP make a copy of your start up partition. Install the Easy BCD program and make a back up again. Then Install Win 7. Then on the Win7 side install the Easy BDC program and set up the menu choices. I run a 3 way boot with XP and Ubuntu. Hope this helps Fix Ya up.
The drivers for Wndows 7 most likely will not work on Windows XP. If this laptop came installed with Windows 7 it may not have Windows XP drivers. Before you install Windows XP check the LG WEB site for Windows XP drivers for your model laptop. If there isn't any XP drivers then I suggest you stick with Windows 7.
Did you try booting into safe mode? if not? try taht.. press f8 before xp bootscreen appear and select safe mode..if you can log onto your pc using safe mode.. click start>run and type msconfig and press enter.. a window will appear, click startup and check if there are any suspicious applications that are enable..uncheck it.. and run a full system scan with your antivirus..once done, restart your computer with the normal process..see if it works..good luck!
Did you try to boot in safe mode? if not, boot your PC, and press f8 after the logo of your unit appears but before the windows xp bootscreen..then comment you can boot
Hi, Yes you can install windows xp in windows 7. Windows XP Mode is a virtual PC image of Windows XP Service Pack 3 that could be run on Windows 7 Professional, Enterprise or Ultimate versions. Applications installed into Windows XP Mode could be run in Desktop Mode or Seamless Mode. In Seamless Mode, applications appear to run natively within Windows 7, but they are actually running inside the Windows XP virtual machine. Windows XP Mode might also provide additional integration that traditional Virtual PC images might not be giving. Applications installed on the Windows XP image could be exposed to the Windows 7 Start menu. Applications run in seamless mode is having automatic access to the Windows 7 known folders like Documents, Pictures, Desktop, Music, etc. Also the Cut-and-paste is enabled between native Windows 7 applications and those running in Windows XP Mode. Applications running in Windows XP Mode might also access your Windows 7 network connection and USB devices.
If it meets the requirements for Windows 7, put the disc in the drive. Reboot, and choose to "boot from cd/dvd drive" (should be one of the f key's, your bootscreen will prompt you on it. After you boot from disc, follow the windows steps for installation.
1. Download and install TuneUp Utilities from the following link: Download TuneUp Utilities You can either purchase the full version or download 30 days trial version. After installation, run it from desktop or from Programs menu or by right-clicking on My computer icon and select "TuneUp Utilities" 2. Click on Customize Windows -> TuneUp Styler 3. It'll open a new window. Click on "Boot Screen" link in left-side pane 4. Now click on "Add -> Load Boot Screen From File..." option 5. Select your boot screen file and click on "Install Boot Screen" button 6. You can also create your own boot screens. To create new boot screen, click on "New Screen" button. It'll open a new window. Now click on "Search Local Drives" link and select the image. 7. Once you finish, click on "Save boot screen" link and provide a name to your boot screen. 8. You can even see the preview of the boot screen by clicking on "Show large preview" link or by clicking on the image in Preview pane 9. Your new boot screen is ready. You can apply it by clicking on "Install Boot Screen" button.
