Your unit doesnt have usb streaming feature (reason it doesnt have a usb jack). connection would have to go thru ilink (ieee1394) connection. that's the dv interface located left side at the bottom of the battery. it's a plug-and-play connection.so basically you need an ieee1394 card installed in your computer to support connection (refer to computer manufacturer), an ieee1394 cable compatible for both your computer and camcorder (uses 4 pin cable), and a video capturing software like moviemaker (for windows) and imovie (for mac).if you have that then your good to go. hope this helps. thanks:)
Testimonial: "Thank you very much for your usefull help"
How are you trying to make them communicate, are you using a USB?
If so make sure you select the proper action when your PC prompts you. Transferring and playing are two distinct things, that is to say, sometimes you may be able to transfer a file to something but, that file may not play due to compatibility.
