Your DVD recorder can be set up to accept remote contol signals on any one of three channels. Remote 1, Remote 2 or Remote 3.
Your remote can be set up to send signals on any of these channels. You need to make sure your recorder and remote are set to the same channel.
Your recorder is telling you that it is set to receive remote control signals on channel 3. This means your remote control is currently set for a different channel.
Assuming that you have a genuine Panasonic remote, do the following,
On your remote press the "Enter" button and hold it down. Then press the "3" button at the same time for two seconds, then release both. This will change your remote so it sends signals on Channel 3 which will match your recorder.
Those clever people at Panasonic realise that you will be delighted with their products and will probably have several of their appliances in use. The different channels avoids switching all your Panasonic gadgets at the same time. Clever huh?
I hv PANASONIC COMMERCIAL TV - MODEL CT 2522 HE. I am facing problem to preogramme all channels.when I open MANU with univeral remote control,or panasonic master remote,I donot find option for PROGRAMME CHANNEL.SOME OF THE CHANELS SKIP,I want all channels to be programmed..pls give the solution
1 It appears that connecting cable is faulty. Normally when you connect and push the power switch the standby light should lit. Try the cable on another appliance and see its function.
Also switch on the TV and try to switch it on with your remote control.
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Check Power Cord is Plugged into Active Outlet Adjust Brightness and Audio ControlsChange ChannelCheck Cable ConnectionsProgram the Remote Control AgainCheck Second Video Source Operation
As warranty has expired, check if fuse at power supply input is ok.
Consult online manual for troubleshooting. http://www.fixya.com/support/p232673-panasonic_ct_36sl13_32_tv/manual-7023/page-22
