Datel Action Replay for Nintendo DS Logo
Posted on Mar 24, 2010
When i put in a code for the action replay it says put in action replay and when i do the screen turns to like a broken tv with stripes going down the screen.
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Mar 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
Helped
3772
Points
20
You can't put it in at that time, or at least that happened to me too. you must have it in already. You can insert it any time before clicking continue.
No codes
hold a and b then turn on action replay when it says this product is not licenced or endorsed by nintendo hold select and start it resests action replay but you can enter codes again. the screen will stay white for a few seconds but that will go away
3helpful
Action replay doesn't let me add codes in custom code list!!!!!
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicolored bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes.
* You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
1. With your console powered off insert the Action Replay DS
2. Hold down buttons A+B
3. Turn your console on
4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
2answers
Help
when you turn on the action replay and see the logo, hold down start & select then turn off your ds. turn it back on, but when you see the ds logo, hold down a&b. then it shows the action reply. your action replay is reset so now, update it with the code manager.
1helpful
My ds wont accept the ards. My other ards wont put any new games in the bottom screen it goes blue and red?My computer (windows vista)doesnt accept my ards
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems: * Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes. * Code Manager PC software is reporting the console`s battery is low when it?s actually fully charged. * Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error. If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased. With your console powered off insert the Action Replay DS Hold down buttons A+B Turn your console on With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen If Action Replay DS doesn?t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again whats an ard? from code junkies
Action replay ds acting CRAZY!!! HELP ASAP HELP!!!!!!
try putting the code in a couple of times then try without the - and then put the id code in fully with the - and hopefully it works
Help
Don't return it! Your Action Replay DS is corrupted. To fix it, turn the DS on (with AR in it) while holding A and B. Then, at the white screen, after "Nintendo DS" but before "This product is not licensed or endorsed by Nintendo", hold down Start and Select while still holding A and B. A few seconds will pass and then the title screen will appear. A few seconds after it appears, release all the buttons. The screen will go white, so just restart the device. Now do a Quick Update in Action Replay Code Manager (on the PC) by pressing the Quick Update button in the corner of the window while the AR (still inserted in the DS) is connected via USB. After it's done, viola! A fixed Action Replay.
5helpful
2answers
My Ds Action Replay Went BLANK!
i have had a similar prob it wiped all the games andm then i could not put more on because it went multi coloured when i tried so i hap to reset the entire thing to do so(source codejunkies):
copyed from code junkies
2helpful
2answers
ACTION REPLAY DS PROBLEMS
I CAN SOLVE IT xD no its not broken
heres what u do :D You hold A+B+START+SEL With action replay in then you turn it on while holding Those buttons then when Action replay main screen comes up Release the buttons and then type ID in then it should work
4helpful
2answers
MY V1.60 DS ACTION REPLAY KEEPS SAYING UNKNOWN GAME TO ANY THING I PUT IN AND WHEN I TYPE IN THE GAME CODE THE BOTTOM TOUCH SCREEN FLASHES RED AND BLUE STRIPES.
i had that problem but now its simple
1.with console off hold a and b
2. still while holding a and b power up
3.as soon as the the ninten stating before this product is ... press start and select and a and b you should be all four
4continue until Main action replay screen is displayed the release it is reset now continue adding you codes
3helpful
2answers
Action replay crashed
First, turn on your Action Replay, and after the warning screen for the DS Pops up, hold these four buttons: A+B+SELECT+START, the white screen will stay up longer than normal, but just be patient.
When the menu screen pops up, let go of the buttons
Plug your DS (Action Replay) to your computer and you should be ready to input games and codes again.
Top Datel Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
