check to besure your power supply fuse is not blown, other wise sounds like you have it connected to wrong 12 volt source, I think there sould be 2 12v connections to the radio one when the car is powered the other constant power.
The best advise I can give is to use the connection that you baught and
cut of the end that connects to your VAN then you need to isolate the
correct leads from your car. The chances are that they wont be the same
colour so if you can get your hands on a voltmeter you should be able to
find the correct leads. The manual for the stereo should tell you the
correct colour wires for the head unit red=live black=neg.
Additionally, send us details about brand, year and model of your VAN, could be there some wiring diagram.
Yes you can. You will need to get an RF adapter and connect it using the antenna or an RF adapter that send out a signal and tuen your radio with either one.
haha, yea sorry about that must have clicked the wrong button... if they spliced that old sony harness to the factory harness and did not cut the factory plug off then you can go to you local bestbuy or car audio store and get an adapter for your factory harness... but, if you have the tools and the time, its faster and cheaper just to hardwire on the new one... as for an adapter to convert the old sony to the new sony plug... ive never seen an adapter for that...
just restart your computer and you will be fine if you cant get to restart just press Ctrl +Alt + Delete Twist and it will restart that should be will you wont loost none of your music are Video
Please press Reset switch in CDX-S2200. You can see it if you de-attache front panel. If problem still exist, then you need to replace IC300 " 6-705-360-02 " IC TDA8588BJ/N2/R1
Press and hold select. Then press select repeatedly until clock adj appears. Then press display and the hour should flash. Press display to switch between hour and minute. Then use the volume up and down to set the hour and minute. Press select and the clock will start and the next setup display appears. Then press and hold select to finish. To display clock press the display button. Hope this helps
