Question about O2 Samsung SGH-E250 Cellular Phone
Phone was dropped and I can no longer use the key pad buttons. other buttons on the front face, eg menu buttons are working.
    President:
  • 1,469 Answers
When a phone drops on the flow it can develop a problem from anywhere in the phone.
You can check the flex of the phone and see if it has shifted from the position it was. After checking the flex of the phone, you can also check the from board where the screen is.
The place that my have caused the keypad not to function will be from the flex of the phone.
Take care.
Posted on Mar 24, 2010
6ya staff
SOURCE:
How to silent the key pad
Go to settings-> phone profiles and tap on the [>>] icon next to the profile you want to make keypad silent (for eg:- normal). from the drop down menu at top right, select phone sounds. Scroll down till you see 'phone sound volume'. Reduce it to zero. Done!!
Jan 11, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I would convert an french my samsung e250
Follow this steps,
1. Press the "Menu" button, or select the "Menu" option, on your Samsung phone. Your phone menu will now appear.
  1. 2.Scroll through the menu using the directional pad and highlight the "Settings" option. Press the button in the center of the directional pad to continue.
    3. Scroll to the "Phone" option and press the middle button. Then scroll to the "Language" option and press the middle button. The phone will now show two fields: "Screen text" and "Input language."
    4. Scroll to the "Screen text" field and press the soft key under the word "Change." A list of the available languages will now appear in a drop-down box. On Samsung phones that use a SIM card, an available option is called "Automatic," which will default the phone to the language of the SIM card.
    5. Scroll to the language you want and press the "OK" button.
    6. Highlight the "Input language" field and press the "Change" soft key. Scroll to the language you want and press the "OK" button.
    7.Press the soft key under the word "Save" to save your changes and return to the phone settings menu.
Nov 23, 2010 | Samsung SGHE250i Cell Phone
Some keys not working
Dust inside key pad , clean it
Apr 23, 2010 | Nokia N70 Cellular Phone
Top 4 keys
you need to take the phone to a mobile tech and have them service the key pads on the phone or replaced them...this will work. :)
Aug 15, 2009 | AT&T Blackberry Curve 8300 Smartphone
Touch pad is not working
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Is there any instance that the phone was dropped or exposed to liquid? If some keys on the phone is no longer working it really needs service.
Jul 17, 2009 | Samsung U900 Soul Cellular Phone
Call button and menu button is not working
its problem flex know change it know its ok 10000%
Mar 15, 2009 | Nokia 5200 Cellular Phone
My key pad is not workin
open your keypad from ur mobile
then give some support to number 4,0,
Eg. some small papen on it
Jun 22, 2008 | Nokia N72 Cellular Phone
Key pad
open the front key face by placing a card on the side of the phone. careful not to poke it harder as there are some chips inside the front slide. once it is open, clean it or try to adjust the keypad face then place it back. If problem still exist, bring it to the mobile center for repair.
Apr 09, 2008 | Nokia N81 Smartphone
Frozen key pad
I have the same problem. Was not dropped or water damage to my knowledge. Just the red button works. When I open it, though, it shows the asteriks key as being pressed which is under the #7 key. Any help would be greatly appeciated.
Sep 08, 2007 | Motorola Mobility RAZR V3i Cellular Phone
O2 Samsung SGH-E250 Cellular Phone Logo
101 people viewed this question
Top O2 Cell Phones Experts
Ekse
Jean Thiebaux
vshirke5
Level 1 Expert
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
