Question about Panasonic KX-T7730 Corded Phone
Http://www.walterbridge.com/manuales/KXT7720-User-Guide.pdf
Get that guide, it is very straight forwards.
Setting voice mail, is only done, through the phone, not by, the phone. page 6 shows you how to log/In out. You need to do this first to be able to access the voice mail. Again, in same page, it shows you step by step via a drawing of buttons, each row of words explains another way to call forward, you just press the corresponding numbered button
Posted on Mar 24, 2010
Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
Oct 27, 2011 | Panasonic KX-T7730 Corded Phone
Dec 18, 2009 | Panasonic KX-T7730 Corded Phone
Dec 07, 2009 | Panasonic KX-T7730 Corded Phone
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
Jun 11, 2009 | Panasonic KX-T7630 Corded Phone
Mar 13, 2009 | Panasonic KX-T7630 Corded Phone
Jan 16, 2009 | Panasonic KX-T7730 Corded Phone
Dec 18, 2007 | Panasonic KX-T7730 Corded Phone
Dec 05, 2007 | Panasonic KX-T7453 Corded Phone
981 people viewed this question
