Question about Smeg UK2010X-1 Pyrolytic Stainless Steel Electric Single Oven
Smeg markings rubbed off
The temperature markings and function markings on my Smeg SA386X have rubbed off. Can I get replacements anywhere??
Posted by fenwickfamil on
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
Symbols around dial of electric cooker have been rubbed out. Can I purchase new stick on ones?
Well, they don't sell stickers anymore but u could buy graffix art stickers numbers that are in different sizes and u could do it by urself!
When sticking those numbers, try to buy the CLEAR COAT paste spray, use by artist and architects, spray it on those stickers to have them laminated for life! Hope that helps u out!
Nov 18, 2010 | Ovens
I have a SMEG SE398X-5 wall oven that does not heat up. The light inside & the controls comes on but will not heat up so there is power to the controls & lights but not to the element & fan.
Hi.
If both baking and broiling element do not heath above a certain temperature, then the part to be replaced is the temperature probe, still located inside the oven cavity.
A faulty temperature probe will keep circuit to the heating elements open, affecting both broiling and baking function.
The temperature sensor can be tested removing it from the oven cavity and reading Ohms on the sensor wires. If the circuit is open at room, then the temperature probe must be replaced.
Regards.
Mar 05, 2010 | Ovens
I have a smeg self cleaning oven on the first occasion I used it when it was just out of warranty to glass shattered and I had to pay eighty euros for a replacement. Last Tuesday I used the self cleaning...
do not use abrasive cleansers on the glass,fine scratches will cause failure in high temperatures. do not use Philip again untill you call around for the best price.!
Sep 23, 2009 | Smeg DO81CSS Electric Double Oven
Symbols have rubbed off for the Smeg SA708 oven
I Have The Same Problem Have You Managed To Work Yours Out??
Aug 31, 2009 | Smeg S1100MFX5 Electric Single Oven
Diplomat ADP3322/3340 oven, temperature markings rubbed off
You can buy the decals from Ovenlettering.co.uk they send you a sketch of the control panel so you know where to place each number.
Aug 29, 2009 | Ovens
SMEG SA708 oven's symbols have rubbed off.
The oven symbols have rubbed off my electrolux oven. It's not even 3 years old. Please can you help?
Jul 26, 2009 | Smeg S1100MFX5 Electric Single Oven
Open Questions:
See all Smeg UK2010X-1 Pyrolytic Stainless Steel Electric Questions
Smeg UK2010X-1 Pyrolytic Stainless Steel Electric Single Oven Logo
Top Smeg Ovens Experts
Paul Bade
Dennis Boxerman
Are you a Smeg Oven Expert? Answer questions, earn points and help others
