Question about Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725
Have lost instruction booklet and do not know how to defrost.
Posted by alippitt on
PNiss
    Scholar:
  • 151 Answers
Easiest solution is to get an ice chest and put all your frozen items in it and turn the unit off or unplug it and leave the door open and let it defrost itself. If you really want to speed it along use a hair dryer to speed up the process. Or put a circulating fan in front of it and put it on high facing the inside of the freezer.
Remember folks KISS, "Keep it simple stupid"
And No I'm not saying anyone is stupid.
Posted on Mar 23, 2010
How to fix a bad defrost control timer frigidaire ffu14fk1cw
Good Afternoon Friend,
I understand you want to know how to fix a bad defrost control timer on your Frigidaire freezer, model# FFU14FK1CW. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to fix the defrost control timer with ease. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Freezers
I have had my True Freezer for a short time. I bought it brand new. I opened my business on Oct 19th. Since then the service man has had to come 6 times to try to correct the problem with the defrost. To...
Hello there: You didn't give out enough informations for me to think what is wrong with a new unit like yours.. What did the serviceman been doing durring these 6 times service call. Did the unit ever work even for one day? Did he change the defrost timer or just made adjustment on the timer. What happen, is the unit icing up so much so that the unit is just a block of ice and that blocked the circulation of the freezing cold air around the unit . Ice is only 32 degree and that is why you only can get 40 degree box. May be the drain tube always frosten up that cause the ice building back up to the coil and form a big lumb of ice. Let me know what is happening , did he add some gas in everytime he service your unit? Let me know more and I will try to solve your problem. Dickson
Nov 04, 2010 | True Freezers
I don't know what the lights mean on my Beko chest freezer. Have just found it defrosted and want to make sure the defrost is off. It is switched on at the mains. What lights should be on? I've lost the...
two reds and green are the auto max freeze on indecators the reds go off one at a time when unit drops to safe temp mode.also means unit needs defrosting manually when too much ice is present.
Feb 03, 2010 | Freezers
Long story but I had someone "attack" my T-72 Freezer and I'm trying to figure out what they did. I think they tried to replace the defrost switch with a non standard switch and stopped half way through...
http://www.truemfg.com/index_en.aspx?language_id=1&event_id=401
Go to this web site. Be sure to have the serial and model numbers. You can request a wiring diagram from the tech line. This is most likely your best place to start. True uses a variety of different devices so I would do this first.
Let me know if I can be of more help after you get diagram.
Dec 07, 2009 | True 72 cu. ft. / 2039 liter Commercial...
I lost the instructions to defrost my new upright freezer
just turn stat all the way up, or unplug from wall.
less there is a manual defrost button.
Sep 14, 2009 | Freezers
FLASHING E8 (WARNING) ON MY FRIDGE FREEZER
A model number and serial number would help in any diagnosis.
May 04, 2008 | Freezers
Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725 Logo
107 people viewed this question
Top Kenmore Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
