Question about Olympus Stylus 850SW Digital Camera
Cracked/dead screen on Olympus 850SW
Hi, When I pulled my 850SW out of my purse this morning the screen was cracked, as far as I can tell the only think that could have done it is my cell phone. So much for it being a water/shock/mangle proof camera.
Does anyone know if it's possible to fix/replace the screen or is it just cheaper to buy a new one?
Posted by mblbrown on
mike fitzsimmons
    New Friend:
I just got one used, was told had a small crack and would not affect it in the water, will it??
Posted on Apr 13, 2013
RAJDEEP DUTTA
  • 2,517 Answers
Hi, if you want you can replace the Screen in low coast. But i like to say its depend on you r country. But if you think in casual way then a new camera always higher price than a camera parts. So i suggest you visit a service center and tell them for replace your camera screen. It will cost approx 25 - 50 USD. Thanks & waiting for your feedback.
Posted on Mar 23, 2010
My new olympus stylus 850sw is not working. The flash settings do not seem to work, and all the pictures turn out either really dark, or a bright white screen. I've altered all the settings, and nothing is...
You could have a problem with the board of the camera. I hope you did not drop the camera. If what you say is happening try to restart the computer of the camera by removing the main battery. It also has a reserve battery and I suggest you remove that too. In about an hour put the batteries back and see if the camera has reset itself. If it does not work I hope you applied for the extended warranty and just send it back to the camera shop if they handle it or directly to Olympus. Good Luck
Jan 07, 2011 | Olympus Stylus 850SW Digital Camera
I have an Olympus 850sw and each time I turn it on it asks to enter the date and time. Why is that?
Most of the cameras with a date time clock have a secondary internal power source like a small watch type battery some point and shoot cameras use a storage cell which takes power from the main battery. This means when the main battery looses power the camera clock will hold a setting for about 1 day or 24 hours. To keep the camera clock set you need to keep a charge in the main battery. Here is a screen shot from the manual explaining this function.
Jan 05, 2011 | Olympus Stylus 850SW Digital Camera
My camera olympus 850 SW the lense turn on violet color thats why when im startng to video or take a picture its color is violet..
i don't have the solution but i experienced the same problem on my olympus 850sw
the images turns violet and the pixels are distorted
never see this kind of error ever a camera had
Oct 18, 2010 | Olympus Stylus 850SW Digital Camera
Flooded my Olympus 850SW while snorkeling in Fiji. I let
Fiji's great isn't it?! Friendliest people and GREAT diving and marine life. A photographers dream, as long as the camera works.
Anyhow, to answer your question, YES, your camera is dead.
May it rest in peace at the nearest electronics recycling station.
If you even get a few drops of salt water in an electronic camera it's either going to be toast immediately, or it won't take long for the inevitable corrosion to do it's magic and kill it. You could send it in for repair, but that would likely cost more than a new(er) camera.
Dennis
Feb 14, 2010 | Olympus Stylus 850SW Digital Camera
Recharchable battery will not charge olympus 850sw
You can download a manual at this site.
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1365
It sounds like your battery is dead. How long have you had this camera? If the battery is not charged properly it will cause the life time to be cut in half or more. When charging these batteries you have to let them die completely before charging. This could be a major problem if your in the middle of taking pictures. I have two batteries for all my cameras that way I always have one on stand by. Hope this works. Let me know if I can help you with anything else.
JimmyC
Sep 28, 2009 | Olympus Stylus 850SW Digital Camera
Cracked screen
Hi
The warranty covers manufacturing defects and such, camera stops working completely etc, cracked screen is not one of those things.
You must have dropped your purse or something must have pressed on the screen and caused it to crack.
I think they will charge you for a new screen.
Sep 10, 2009 | Nikon Coolpix S210 Digital Camera
Blurry lens after using it underwater
Sadly that symptom indicates that the camera is broken.
The device's seal protects both from the condition that you are seeing, but also protects the internal circuits from moisture.
If water has gotten inside the camera, I would pursue returning it and getting a replacement from the company.
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Apr 29, 2009 | Olympus Stylus 850SW Digital Camera
Is the Olympus 850sw digital camera waterproof?
You probably know by now that the 850SW is waterproof, shockproof and also stands up in freezing conditions. I am just writing because I am very happy with mine and would highly recommend it for your active boyfriend. We have gotten many great pictures with it in the water and the kids have been pretty rough with it at times.
Olympus also has newer versions of this camera, the 1030SW and the 1050SW. I saw the 1050SW today at Costco for just 229.99.
Nov 17, 2008 | Olympus Stylus 850SW Digital Camera
Olympus Stylus 850SW Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jax Planet
Jax Planet
Are you an Olympus Camera Expert? Answer questions, earn points and help others
