Computers & Internet Logo
Anonymous Posted on Mar 23, 2010
Is print shop version 21 compatable with win 7?
Is Broderbund, The Print Shop version 21 compatable with win 7?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 247 Answers
  • Posted on Mar 23, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
247
Questions
Helped
80410
Points
669
Http://www.broderbund.com/store/broder/en_US/DisplayCategoryProductListPage/New_Releases/The_Print_Shopreg/parentCategoryID.13527700/categoryID.13528200
If even the earlier version isn't compatible,and my search only shows upto 2.0,then I would assume that 2.1 isn't ready either.
Testimonial: "Thank you! It doesn't make my wife happy but at least now she knows!!"
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 16, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
152
Points
0
I have windows 7 and print shop deluxe 20 it is sayingn ot compatilble is there a solution
1helpful
Is it possible to install Print shop version 11 on windows 7?
according to their site its not compatible to Win 7 means it can install but not all most all the functions are available but they are up to release a new version with compatible to win 7
2helpful
2answers
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
1helpful
Can not install Print Shop Pro Publisher Version 21 will not load on Windows 7
You can try setting it to run in compatability mode.
Right click on the program Icon
Click properties
Then click compatability tab
Check mark Run this program in compatability for
Select windows xp in the drop down list.
Click apply then OK
Try running the program
If this does not work try
Right clicking on the icon of the program and selecting run as administrator.
This program version is not supported by Windows 7 so if this does not work the you will need to upgrade to Version .23 instead of .21
I have the full version of print shop deluxe22 and it won't let me install it on my hp laptop HP G71-442nr Notebook, Running windows 7
Print Shop 22 Deluxe is not compatible with Win 7 (x86 or x64bit) Operating.
You have to use the Print Shop 22 Deluxe version 23.1 - compatible with Win 7 & Vista.
Hope it helps.
I purchased printshop 20 deluxe and installed on my computer which has windows 7 installed on it. The installation shows it was successful however when I try to run the printshop program it tries to start...
The Print Shop version 20 Deluxe for PC is not compatible with Windows 7. The newer Version 23 is compatible. This is due to software compatibility issues with Windows 7.
You can check for Win 7 Compatibility for "software or hardware" @ Windows 7 Compatibility Center
It will not run on Win 7, even when you are using the Compatibility Mode options. Too bad you have to get the newer version 23.
Hope it helps.
Installing Print Shop 21 in Windows 7
Print Shop version 21 Deluxe is not compatible with Windows 7. You have to use a newer version 23 which is compatible. This is due to software compatibility with Windows 7.
You can check forcompatibilites issues @ Windows 7 "software & hardware" compatibility center
2helpful
Unable to install Print Shop verison 11 on my Window 7, why?
Print Shop Pro Publisher version 11 was built for Platform OS: Windows 98 / Me / 95. It is an old software which is not for Windows 7(x86 or x64) OS. This is due to software compatibility issues with Windows 7 ie an old software running on a newer OS Platform.
You have to get a newer version which is compatible with Win 7.
Hope it helps.
1helpful
2answers
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
2helpful
Making printshop 21 run properly on win 7
You can either get Broderbund Print Shop Deluxe 2.0 which is Win7 compatible or use a virtual/dual boot computer with WinXP. (The Vista compatible version was Print Shop 23; so you are dealing with some significant changes in the OS. Thus the compatibility mode probably won't work. You can try right clicking on the installer and choose Properties and the Compatibility Tab. Check Run as Compatible with XP then right click on the installer again and choose Run as Administrator. Then do the Compatiblity mode again with the actual program.)
With Win7 Pro and Ultimate, you have an option to download and run XP mode which takes two programs that you download from Microsoft and install. This lets you run a virtual XP computer inside the Win7 computer for free. All other virtual computer programs or dual boot systems require a licensed version of XP.
I hope this helps.
Grand Canyon Tech
Grand Canyon Tech
