SOURCE: Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
SOURCE: drum makes loud noise when spinning
The bearings are worn out ,it's not worth to repair , the fact that your washer is old it's going to have more problems.
SOURCE: not spinning
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
It spins only with the lid closed
For
safety, washing machines are made so that they spin only with the lid
closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: Indesit WM 12 X
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive noise. There can be several causes and the problem is worse with some machines more than others.
The most common cause is an unbalanced wash load. Open the lid and when it comes to a stop, redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit.
A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See our article on how to level your washing machine.
The outer tub is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be called for.
Another common cause for excessive movement is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.
There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
Click here to order replacement parts.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Hi
If its rattling check the drum for anything
caught in it.Washing machine noise is not only annoying, it can also be a sign
of serious damage. When armed with a few tips, you can determine what problem
may be causing your washing machine to rattle, and what you can do to stop it.
Check for drum bearing failure if your washing machine is noisy on the spin
cycle. Drum bearing failure is common when the bearing seals start allowing water
to enter. You can take the belt off and spin the drum by hand, and if the drum
rumbles, replace the bearings.
Turn the drum by hand and listen for loud
noises. If the drum itself is split or the 'spider' is corroded, broken or has
come apart from the back of the drum it will create a loud noise on every turn
of the drum. (When the bearings have gone bad, the noise is constant the entire
time the drum is spinning.)
Look for obvious dents and creases in the
drum or look for coins or small objects stuck inside the tub underneath the
drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like
coins or small objects when a noise occurs while the washing machine is
emptying water.
Remove the sump hose and look for bra wires
if you hear a light scraping noise when the drum is turned by hand. You can
also check to make sure a wire isn't poking out of one of the holes in the
drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if
you hear a high pitched squealing noise to check for motor bearing damage or
wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further
query or else please accept the solution.
Thanks for contacting fixya.com
