Question about NetGear PS121 Print Server
How do i manually install the print server? - NetGear PS121 Print Server
Posted by chrispiep992 on
Anand Gupta
  • 1,272 Answers
You can check the steps to configure the print server using the steps as mentioned in the below link:
PS121 configuration
Hope, this helps you to fix the issue. If you need any further assistance then do let me know.
Regards
Anand
Posted on Mar 23, 2010
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
I have a tplink PS310U MFC print server. I have managed to connect using a PC but there is no software for the Mac OS X. I am running Yosemite and can connect to the server for printing. However I can
Hi
If you can't scan then it sounds as if your computer doesn't have the appropriate driver installed for scanning. There are a lot of drivers and other downloads here:
Printers
including a scanner driver for MAC OS 10.3 to 10.7. Since Yosemite is 10.10, I don't know if this would work for you, but I think it your most promising solution.
It may be worth disconnecting the printer and connecting it directly to the computer. If it scans and prints when directly connected then it is likely that the print server is causing the problem and if as you say there is no Mac software for it you may be in a no-win situation. The fact that you can print through it however does mean there is hope, because I have found this page which is described as manual installation of the server on Mac OS here
FAQ ID 347 How to install Print Server manually on MAC OS
but the OS is 10.6.4 so, I'm not sure.
Not as helpful as I had hoped but perhaps you can get something from this screed
Dec 17, 2014 | TP-LINK ACCESSORY TL-PS310U SINGLE...
Ineed the INSTALLATION CD for the WS-NU72P11 REV A USB 2.0 PRINT SERVER
This print server is made by Winstars and sold under many other brand names: Vibob, MC-Power, etc.
Go to the Winstars website under : Home > Customer Service > Download > DOWNLOAD DRIVERS AND MANUAL, and look for model WS-NU72P11.
You can download the installer program and manual there.
It is the first result when you Google WS-NU72P11.
Download page is: http://www.win-star.com/eshop/article.php?id=41
Aug 11, 2014 | Computers & Internet
I am using DP-301U print server and wanting to attach with hp 1020 plus. However the printer in not printing. what is the root cause and give the solution please...
Hello and welcome to fixya.
First off, I would like to provide you a link with the print server's manual to download it directly and have it as spare.
The printer you are trying to install is a laser printer (black/white only) and probably a bit old model.
Therefore, if you are trying to print from your computer over ethernet, and you have windows vista or 7 (64 or 32bit accordingly) you might have the inappropriate drivers for either the print server or the printer. You can find all of the HP printer's drivers HERE. Select carefully based on your OS.
As a SIDENOTE: If you just need the drivers installed and there are only larger setup execut. files available, you can use 7zip or winace to open up the *.exe file and navigate to the appropriate folder and extract only that one to your computer and install the driver(s) from there.
The D-Link DP-301U print server drivers are available HERE. Default username and password for the management console of the print server can be found at pdf manual page 25. The url to access the administration console is dlink-******,where the asterisks stand for the last 6 digits of the print server MAC address.
Overall, not to make things over-complicated (150+ PDF user manual pages) you need to do the following:
1. Install the appropriate drivers of your hp printer on the computer that will have also print serv. softare installed.
2. Install the appropriate software/drivers of the dlink print server on the same computer.
3. Plugin the usb cable of your printer to the print server's USB port.
4. Plugin the ethernet cable of your print server port to the ethernet port of your home router/switch.
5. Setup Fixed IP settings for your print server configuration (page 20 on the manual).
Let me know how that went. I believe you will manage to do it that way quite easily.
**Don't Forget to vote how helpful this was.**
Thanks.
Regards from FixYa.com
Apr 22, 2011 | D-Link DP 301U (DP-301U) Print Server
I've connected the Zonet PS to my Linksys router and the light on the router is green. The PS wizard does not see it from either my wired PC or wireless laptop. Is there a setting on the Linksys router I...
ZPS2102, ZPW1000, ZPS1000 :: Trouble shooting tips for finding the print server using the utility
supporting troubleshooting links
? A: Please check the connection link light.
Temporarily disable all firewalls on your system even the Windows XP firewall
(for instruction to disable XP firewall, please go to http://support.microsoft.com/kb/283673 )
Power cycle the print sever by unplug the power at the back (10 second).
The print server default IP is 192.168.5.1
Set the computer which has the print server utility installed to have an IP of 192.168.5.2
(Test ping the print server / 192.168.5.1 --
If print server is respond to ping, using web browser with the address of 192.168.5.1 will also beable to configure the print server)
Run the utility/hit the refresh button to find the print server again.
The CD has two installation methods:
1. The Auto run will run the utility.
2. By manually install the program into your system. (Browse CD to the folder: manual installation.)
It is recommended to use the 2nd method and run the PSAdmin utility from the system's programs after the installation is completed.
If it still could not find the print server, direct connect your computer to the print server using cross over cable and run the utility again to find the print server.
When it finds the print server, change the print server IP(192.168.5.1) to a unique static IP your router can accept. Put the print server back to the network, change back your computer's IP accordingly and try ping the print server with the new IP or run the utility again.
For wireless print server, it is recommended to use Ad-hoc connection from a wireless computer to connect to the print server first. (follow the Quick Installation Guide booklet that came with the box on page 8)
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Jan 30, 2011 | Zonet ZPS2102 Print Server
Linksys Etherfast Printserver model no EPSX3 getting error Print Server Failed, can you tell me how to fix it or why it's happening?
HI,
You will need to check the settings of the print server.
are trying to run the set up disc of the print server.
You can try to install the print server manually.
Click Here for more information
Oct 06, 2009 | Linksys EtherFast PrintServer Print Server
Setting up my D-Link DP-301P+ print server
Print servers are typically controlled through a web interface, and do not need specific drivers. You can download the manual and installation guides here. You may need to change the default IP address; look at the section on Networking Basics in the manual.
Jan 11, 2009 | D-Link DP-301P+ Fast Ethernet Print Server...
Wireless-G WPS54GU2 Print Server Lost disk
if you visit the LinkSys website you should be able to download all applicable drivers and files for this print server. Also you will likely be able to access a user manual (in PDF format) which should give you all the information you need.
May 27, 2008 | Linksys Wireless-G WPS54GU2 Print Server
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
Dynamode WL-PS-1P Print Server Manager Admin Password
password is 1234
look on instalation cd it contains a full manual great detail
Jan 22, 2008 | Dynamode (WL-PS-1P) Print Servers
NetGear PS121 Print Server Logo
342 people viewed this question
Top NetGear Computers & Internet Experts
Mike
efs_perpends
efs_perpends
Lee Hodgson
Lee Hodgson
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
