SOURCE: flm 3232 polaroid
The power supply is only supplied with the control box. The control box is listed below.
Polaroid FLM3232 Control box with Power Supply
SOURCE: Polaroid LCD FLM-3232 Television
Go to http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen. Stiv0 posts the fix at the top, but go down about 10 posts or so and read mine (BlakeFromGa). I have some slight differences to my fix and a list of what you'll need.
SOURCE: Sound but no picture.
It sounds like it is the picture tube. The same thing just happened to me. The back of my television started smoking and then there was no picture.
SOURCE: FLM-3232 Screen Shattered
ky9c1le,
I have a flm3232 with a dead supply (I think). Maybe we could strike up a deal. Contact me at [email protected].
SOURCE: I need help fixing a Polaroid FLM-3232 w/o power
I do not know what your problem is as you do not even describe a problem, but I dare say capacitors do not need to be bulged to be deffective.
Usually the ones closest to heat source are the ones to dry first; bulging can be result of a too strong current running through them too and not neccessarily related to heat.
Usually they are large and close to the connectors that carry power from the power board to other internal boards.
Other capacitors may also be affected, of course.
You can try your luck replacing them in order, bring the TV to a specialist or start reading the theory of repairing SMPS - you can find it online, an excellent read if you really want to get into it.
