Dishwashers Logo
Anonymous Posted on Mar 23, 2010
I get an E1 error code. If I check the water level it is low so if I put in about two quirts of water it runs for only that water cycle, then I have to put in another quirt for the next cycle. The water comes to the same level every time. Can you point me in the right direction?
Anonymous
Level 2:
Scholar:
  • Expert 106 Answers
  • Posted on Mar 30, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
106
Questions
0
Helped
37175
Points
228
Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Replace the connections of hose. Check the point of damages and repair or replace the related parts. Correct drain connections. Replace the impeller of the washing pump.
My LG intello dishwasher LD2050SH gives me an E1 error
AE & E1 ERROR CODE - DISH WASHER
LG Electronics https://www.lg.com > support > help-library > ae-e1-er...
Nov 8, 2023 - An AE or E1 error code means you have a leak inside your dishwasher activating the float switch. Before you can start using your dishwasher ...
Missing: LD2050SH ‎' Show results with: LD2050SH
Help library: AE & E1 error code - Dishwasher
LG Electronics https://www.lg.com > Home > Support > Troubleshoot
Dec 13, 2023 - The AE or E1 error code indicates a possible leak from the unit. ... Then run an empty cycle with nothing in it to clean out the dishwasher. If ...
Missing: intello ‎ LD2050SH
LG Dishwasher - Error Code List ' LG USA Support
LG Electronics https://www.lg.com > support > help-library > lg-dish...
Jun 20, 2023 - If overfilling occurs, the flow switch will trigger an E1 error code and your dishwasher will turn off to prevent outside leakage.
Toshiba washing machine AW9790S show error code is E3-1,need solution to fix it
3. Toshib washing machine error code:
  1. E1 : Water discharge error.
  2. E2 : Safety lock error (Door switch).
  3. E3 : Laundry is unevenly distributed inside the washing bucket.
  4. E3 : Laundry is misaligned, cage screws are loose, the balance ring is open, the clutch is loose, the door switch loses the spring (due to the screwing of the cheek), the switch wire is blocked, the safety lever is blocked. .
  5. E4 : Damn buoy.
  6. E5 : Water supply error.
  7. E6 : Washer motor, too much, low water level, clutch shaft, clutch shaft.
  8. Ec1 : Many laundry or little water.
  9. Ec3 : Many laundry or little water.
  10. Ec5 : Many laundry or little water.
  11. Ec6 : Many laundry or little water.
  12. F : Multi-wash or charring.
  13. E7 : Washing motor jam, too much, low water level, clutch shaft, sanso clutch.
  14. E7-1 : Memory overflow error, programming: press the water level, timer, discharge, open the power, and the pip pip remove the power and about 1 minute of the pin works well.
  15. E7-4 : Word count error.
  16. E8 : Washing motor jam, too much, low water level, clutch shaft, sanso clutch shaft.
  17. E9 : Water leaks, the washing bucket is broken, the valve is stuck, entangled with the senso of the broken water, do not forget to check the wires.
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
How do I reset e1 error code on LG dishwasher after kid puts dish soap in the machine?
The suds may have caused water to run down into the pan under the unit. Take the front kick panel off and look for water under the unit and in the catch pan.
Which error e1 of hoshizaki ice maker fm-170ake
E1, means low ice production
Ice machine cycle takes to long to call for a harvest. When this happens it should shut the whole unit down and then show the error code. Reset power supply, Turn off then Turn on the machine. Check for these problems. Gas leaking by the hot gas valve when in freeze mode, this valve should only let hot gas by when it is in a harvest mode. Check water control valve to make sure it is not letting water in during freeze cycle. Check water float switch to make sure it is not stuck calling for water during freeze cycle. Also make sure the machine is not in a hot location, the hotter the ambient surrounding air entering the condenser coil the longer it takes to make ice.
4helpful
2answers
I have an E1 message on my samsung front loader, can you tell me what that means?
Is the system filling up with water then halting with an E1 error or can you complete an entire cycle?
E1 in Samsung Front Loaders: It means the machine has detected an error in inlet water filter or the water pressure. Some of my sources indicate E1 could also be a leakage error It could all mean a faulty sensor but you should check th water lines, the door seals and the floor beneath the machine for tell-tale signs of a leaking system. Is the system filling up with water then halting with an E1 error or can you complete an entire cycle?
If you can fill the washer, but it faults with and E1, and can go no further, my research shows a common cause for the problem is the PVC tube connecting the pressure sensor to the drum has experienced a problem. In some modern washers, the water level is measured and regulated with a pressure sensor connected to the tub with a plastic tube. As the water level rises inside the drum, the pressure rises inside the sealed tube. The tube can sometimes become detached or even plugged with lint, soap or wash grime. Check the pressure sensor line to make sure it is attached to the drum and is completely unobstructed by foreign objects or deposits. If so, clean the debris and/or reattach the tube to the drum and try running starting a cycle. If you don't get the E1 code - Hooray, everyone has clean clothes again :-)
If this does not work, here is a link to a Washing Machine User Blog which might be able to offer more experts and more specific information http://www.applianceblog.com/mainforums/washers
Hope this answers your questions and helps FixYa! If you found my information useful and informative, won't you please show some love and rate this solution or better yet, send us a brief testimonial on how our free support made your day and averted disaster.
Thank you for choosing FixYa.com.
Colt Baldwin - FixYa.com Guru
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
2helpful
Lg intellowasher dishwasher gives error 1 on all cycles
If it's 00:E1. You need to check the water level sensor, and the thermistor.
If the display is E1. then you need to check for water leaks, or restrictions inside the impeller inside the pump.
Dec 23, 2009 • Dishwashers
LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
Not reached to the normal
water level in spite
of 10 min. water supply
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker
L g steam washer front load
The model you have this listed under WM2688H (LG Steam Washer) a E1 Code Correct water level (246) is not reached within 8 minutes
after water is supplied or it does not reach the preset water
level within 25 minutes.
I suggest you
Check the screens in the water inlet valve for blockage
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
