SOURCE: need code for a legend tv
Hey there,
This brand uses the same code as sylvania/emerson. Try using the emerson codes, and that should give you the basic functions with remote. Here are some of the emerson codes. Just drop first 0 if your remote only takes three #s. Try each until one works. Good Luck!
0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, 0185, 0282
SOURCE: universal remote px-rc1
Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too.
Mcneileric is right!
Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up.
NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV!
Again...
TV onPress and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 secondsPress SET againPress Power to check if the TV turns off^^If nothing happens, press +CHANNEL to search for codePress Power again to check if TV turns off^^If nothing happens, repeat the step between ^^ and ^^If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup.
Mcneileric, THANK YOU!!!!
