My YSP 1000 no longer powers on, this problem started gradually. At first I could only power it up (after having put it on standby) by removing the powercord, put it back in and then pressing standby button. Now this doesnt work either. I removed the backplate and checked the fuse and its not blown.
C515 ON THE MAIN POWER PCB (HAS 223 K 630HI PRINTED ON IT) HAS FAILED
Replace with a 22nf capacitor - Maplin was part number N38CN (Not a 220nf !!)
the new maplin part has a higher voltage rating and is bigger. it will need to be fitted with the leads extended with wire to get it to fit.C515 ON THE MAIN POWER PCB (HAS 223 K 630HI PRINTED ON IT) HAS FAILED
You can't post conmments that contain an email address.
C515 ON THE MAIN POWER PCB (HAS 223 K 630HI PRINTED ON IT) HAS FAILED Replace with a 22nf capacitor - Maplin part number N38CN the new maplin part has a higher voltage rating and is bigger. it will need to be fitted with the leads extended with wire to get it to fit.
u have a cool sound projector but u have a baaaad power supply system. bad power supply design - u will get all sorts of noise when u power it up. i have a sub woofer with the same problem(which in my case is the way it is designed). i used a delay circuit. but in ur case i know YSP-1 has a clean start up. so, if the warranty still covers it get it replaced. static noises, pop noises are often caused by bad capacitors.
C515 ON THE MAIN POWER PCB (HAS 223 K 630HI PRINTED ON IT) HAS FAILED Replace with a 22nf capacitor - Maplin part number N38CN - the new maplin part has a higher voltage rating and is bigger. it will need to be fitted with the leads extended with wire to get it to fit.
The best way to get quality sound would be to go through the USB connection of the phone.
It will be hard and a bit costly to get a cable to link the Ipod and projector.
Easiet and economical way is to go to apple and purchase a cable for the jaudio jack at the top of the Ipod that will also have an audio jack connector for the projector
I had to start my acerpower 1000 four or five times. When it boots into windows, it lasts for about a minute, then shuts off.
When booting into safe mode, the PC will stay on forever. I would think a hardware problem would cause it to always shut off.
This is not a solution, but something I have observed about these machines.
