Want to connect 2nd sata hd but only 2 motherboard connectors ... 1 already used by 1st hd and 2nd used with dvd rom .... is there a cable to enable this set up ?
these may vary depending on the make of your hard drive
enable cable select:I:: master or single driveI:::
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
