My hotpoint dryer wont stay running. You can turn it on and it runs for a few seconds then stops. I have to wait about five mintues then try again and it doe sthe same thing.
Is the drum spinning easy ?with no metal to metal grinding sound ? could be the start run capacitor for the motor its black/ round and is on the side of motor //or the motor windings have overheated 2 manny times an swelled the windings ///the drum shaft sleave/bearing could be wore out or gone //the front drum slides could be wore out or gone //kinda need a little more info.. hope this helps.. let me know., an good luck
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
