Hi.
The unit goes on protected mode when an internal fault is detected.
Try disconnecting the battery cable for five minutes . If there is no fault you will clear protected mode.
If the unit still goes on protect, then check the wiring at the back, a short in there can trigger protectedd mode. If that does not work, then there is an internal fault. In that case the unit must be disassembled and tested.
Regards.
