Question about Samsung YP-S3JAB Digital Media Player
How can I erase all my music?
How can I erase all my music? I'm trying to access my files from my computer but it won't allow me to erase them. If I reset it would they be erased then?
Posted by cutiestpoohb on
Thermo King
  • 593 Answers
No just a reset will not cause files to be deleted. You will have to format the drive. See this tip posted here to help it is for a Sansa but it will help you understand. Sansa Mp3 player frozen? How to reset and...
Solve your MP3 Player Connection Problem.
Posted on Mar 23, 2010
How to delete music files from ipad?
You should try iPhone Data Eraser. It's designed to erase data completely from iPhone/iPad/iPod. Here are steps about How to Delete Music from iPad.
Step 1.Install iPhone Data Eraser on the computer and connect iPad with computer.
Step 2.Choose "Erase All Data on Device" on the list.
Step 3.Delete music on iPad. "Medium" level is the most common choice. Click "Start" to erase.
It's so convenient. You can not miss it!
Jul 30, 2014 | Apple iTunes
All of my file got erased on my coby mp3 610 when i preased the reset button
When you reset a device, it often clears the entire memory of the device and reverts to original settings. you can copy all of the music back on from a computer, but won't be able to retrieve it on the device.
May 04, 2011 | Coby MP-610 MP3 Player
How do i reset and erase the music files so i can download different music on it
hook it u to your computer and access the mp3 playr in the my computer and tehn you should be able to manually erase the files
Jan 05, 2010 | RCA TH1101 MP3 Player
I cant erase the music off of it!!!
Plug the device into your PC via the USB cable, open "Computer" in Vista or "My Computer" in XP, find which removable drive it is listed under, for example G, H, I, K etc. You'll have to double click on each one of them until you find it. Once you find it, search the folders for the music you wish to erase, highlight it, right click, then click delete as you would with files on you PC that you want to erase and you're go to go.
Sep 05, 2009 | Memorex MMP8565 MP3 Player
I have a sylvania mp4 smpk1021.i wanted to put new playlists on and deleted the old ones. it said "empty disk".i try to add new playlists, but songs that have already been added before are somehow still on...
is it posible to format the whole player from the computer or reset the player so that all the files are erased from it so you can add new playlists, like doing a hard reset to factory settings and erasing everything if it is possible to format it from the computer i wouldnt do it if it shows files that the player needs when you plug it in to the computer but i suggest doing a hard reset on it heres the manual link http://www.curtisint.com/web/browser.asp?productID=SMPK1021&catName=&brand=SYLVANIA&manual=SMPK1021 it might tell you in there how to hard reset it or how to fix it
Jun 04, 2009 | iLO MP3 Player
WMP 11 can't access files to sync with sansa clip
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
Most other problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
Jan 05, 2009 | SanDisk Sansa Clip MP3 Player
I own a Dell Optiplex GX150. I am trying to access the system partition that will allow me to restore back to my factory settings. This computer was purchased back around 2001 and did not arrive with any...
Contact Dell technical support to get the CD read the partition on your hard drive to restore to factory settings. It won't be able to work without one since it has to boot from the CD in order to get it to work.
Dec 10, 2008 | Dell OptiPlex GX150 PC Desktop
Music file that can't read or earse
You can reset the whole phone if you have already tried erasing it from its apps menu. Keep in mind that thid will erase everything (data, media, etc). I suggest you load all your media files to the MMC (mem. card), instead using the phone's mem.
To Reset:
menu Settings/Tools----Phone Settings---Security----enter user code--select Reset Default. Phone will off then on aftter 1 or 2 by itself.
Jun 07, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Music & memory loss
so i guess ur done with it..
May 01, 2008 | Sony NWZ-B103FBLK MP3 Player
Erase everything from my Sandisk M230
Just download the mannual from the google search site to learn how to reset your player..!!!
Thankyou
Feb 01, 2008 | SanDisk Sansa m230 MP3 Player
Samsung YP-S3JAB  Digital Media Player Logo
109 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
