Question about Sony HT-CT100 Theater System
How to set up a soundbar with a subwoofer. Where to place the subwoofer. Does it need to be behind us? Is it ok if its in a corner? Will it sound as good if it is in front of us next to the tv?
Anonymous
    Novelist:
  • 156 Answers
The subwoofer deals with low frequencies, which are not very directional (ie, it's harder to tell where the sound is coming from).  So where you put it isn't critical to the sound, provided that it's not behind curtains or something that will soak up sound.  The bigger speaker you have in your subwoofer; the less important the position is.
Putting it in a corner is something you're going to have to try, but you may even end up with better bass if you do, as a corner can act as a soundbox and emphasise bassy sounds.  Conversely, your subwoofer may not like being in a corner and interference effects from the sound reflections could degrade the sound.  Like I say, try it and see what it sounds like.  It depends upon your subwoofer, what else is in the corner, precise positioning, and how reflective to sound the corner is.  If it sounds terrible, move it a few inches and try again.
You can put it in front of you next to the TV, no problem.  The only downside it it's a big ugly box.  My wife always makes me hide my subwoofers behind something.
Posted on Mar 23, 2010
Testimonial: "Thank you, very helpful."
Can't sync my JBL SB400 subwoofer to the soundbar??....it flashes blue and goes back to orange. Sound bar works but can't pair sub!..HELP!!
PAIRING THE JBL SB400 FOR WIRELESS OPERATION
After turning the soundbar and subwoofer on for the first time, you will need to "pair" the subwoofer and soundbar so they both operate at the same wireless frequency. To pair the units, press the Wireless Pairing switches on both units within 30 seconds of each other. The units will communicate with each other and operate at the same frequency.
May 21, 2015 | JBL Audio Players & Recorders
Subwoofer not working.
Most likely, the "remote" wire to the subwoofer amplifier has come off or is not making good connection.
May 15, 2015 | JVC TH-BA1 Soundbar System with Wireless...
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
Vizio help
Not sure the issue. HDMI from cable box to TV. Same with Vizio.
The soundbar usually connects to the optical out from the TV to the in on the soundbar. Subwoofer has to be paired to the soundbar. Instructions should explain or maybe find online by manufacturer
Aug 15, 2014 | Televison & Video
The blue light still continues to flash
Push in and hold the switch on the back of the subwoofer until the light starts blinking fast. Then, with the soundbar power turned off, hold the mute button on the remote. "ID SET" should show up on the display. Then turn on the soundbar, and the subwoofer should link to it.
Oct 31, 2013 | Samsung 40" AudioBar w/ Wireless Subwoofer...
Can't get sound out of Boston soundbar when hooked up to 46" LCD Philips? Soundbar works fine when hooked directly to iPod.
You may have to go into the settings on the tv and turn off the internal speakers in order to get audio out of the jacks on back.
Dec 27, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
I have the tvee soundbar with wireless sub and the soundbar works fine but my sub just makes a thumping sound like a heartbeat. i have tried moving it, switching frequency channels, different outlets with...
It is not latching on to the soundbar transmitter. Is the locked light on the device turning on.
Wireless devices are sometimes known to drift. Is the sub silent when the soundbar power is off ?. Even then if its making this sound, the subwoofer amplifier is oscillating at very low frequency. You will need professional help and needs to be repaired.
Mar 10, 2011 | Boston Acoustics TVee Model Two TV...
Sony HT-CT100 Theater System Logo
1,274 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
