Question about Krell KAV-300i 2-Channel Amplifier
I think maybe the xlr input might be going bad. There's nosie and amplification irregularities coming from one chanel. When I unhook the chanel, it makes a noise( bad connection noise). When I unhook the other chanel, no noise comes out of it. I think it might be an xlr connection that might be going bad.
  • 120 Answers
Try switching cables from one channel to the other and see if the problem follows the cables.
Posted on Apr 12, 2010
6ya staff
SOURCE:
My Behringer PMP1280S INPUT Chanel 1 is no longer working, after pulling out the mic XLR plug whilst the amp was still turned on.
You should be able to unplug a mic from the xlr input with the unit on with no problem.
I beleive the problem is that the xlr input jack has one or more legs broken off the board. If you dsassemble the board and resolder the three legs to the board you'll probably fix the problem.
Dec 01, 2015 | Behringer Music
How come chanel a does not work on the pyle pro pta 1000 is it the way i hooked it up
Without seeing what you have... It comes down to this. Bad amp. Bad input. Switch your RCA cable, if the side is still out.. Unhook speaker, test it with a meter, small batt. Like a 9 volt. If if pops speaker is OK. No pop you have bad speaker, disconnected or bad wire.
Nov 22, 2014 | Audio Players & Recorders
The Clip LED on Channel 1 of my SA220 is on continuously even with nothing plugged in the XLR or 1/4 inch inputs. Not getting amplification when inputs are used. Why?
That light is showing that there is power to amp in that speaker but there is something wrong with the amp or the speaker inside and nothing is coming out. You will have to troubleshoot the amp and check the resistance of the speaker to see what the problem is.
Nov 12, 2014 | Fishman SA220 Solo Performance System...
What would cause my Marshall Mode 4 amp to not change channels?
That can be caused by a faulty switch contact. I presume channels can be selected manually.
Aug 05, 2014 | Marshall Amplification Marshall AR-AM4,...
I have a 2006 cadillac escalade and my speakers went out, they come back on every so often but they stay out for the most part.........i'm thinking it's amplifier.....need some help, what can i do
If you can finder your amplifer check the connections for your wiring. You could jus have a bad ground wire that has a weak connection or a hot wire going to your amplifer that has a bad connection aswell. If it is a bad connection then when you hit bumps going down the road is probably causing them to come on and off without your control.
Sep 07, 2011 | 2006 Cadillac Escalade
Can a technics su v670 be wired up with a technics power amp a800s mk II?? what im thinking it doubles up on the power the wattage to each channels? am i rite? the suv 670 is 90 watts per channel and the...
"im no proffetional at this". Really?
If you looked at the manuals for either product you would NEVER find a recommendation to use one amplifier's speaker input to drive the LINE LEVEL (very small) input on another amplifier. Speaker outputs are for driving speakers or amplifiers designed to accept speaker-level input (like some self-powered subwoofers). In no case is the power of the originating amplifer BOOSTING the power of the driven one.
You should do some reading on how amplifiers work before you blow something up and come asking for advice on how to resolve it.
Sep 02, 2011 | Audio Players & Recorders
Very bad hiss even when power is turned off and battery is removed
If you use a sennheiser check your Squelch is not set to high / low. I use a Z1 and that solved my problem.
Feb 07, 2008 | Sennheiser EW100ENG-G2 2-Way Radio
SR71
I am not sure about this model of mic but it could be as easy as twisting off the bottom. There could also be a screw near the XLR jack that has to be removed, or tightened. Some mics have the XLR jack glued in pretty tightly. I am giving you suggestions based on other mics, I haven't touched a SR71. Hope that helps! Baze
Jun 27, 2007 | Earthworks QTC30 Omni Professional...
90 people viewed this question
Top Krell Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Lawrence Oravetz
Are you a Krell Audio Player and Recorder Expert? Answer questions, earn points and help others
