Nothing showing up on the screen, definitely not a monitor issue the way you describe it. And you did all physical repair checks and such? Then the most likely problem I see is with the operating system. Windows Vista is so glitchy that any number of things could go wrong with it. I wouldn't put it past that OS. If you could get past the monitor issue perhaps you can uninstall that OS and upgrade to windows seven. Otherwise I'd take it in for a more professional diagnosis =/
Try to boot first in bios, if it work normally restart and press F8 and start in VGA mode select screen resolution to 800 by 600. if still not work re-install windows vista operating systems.
SOURCE: I am working on a
The last step is indeed the replacement of the video card - if even that fails then the motherboard is dead, it needs a new one.
