Question about Dacor ECS130 Epicure Electric Single Oven
I want to re-set high temperature limit control, but don't know where it's located
Posted by Del Allen on
ejasperse
  • 189 Answers
Hello- The reset is located inside the oven at the top. Remove the screws and pull cover. Use a flashlight to find the little red button and push it in with a little screwdriver until it clicks. Should solve this problem. Wish all ovens had this button.     Please acknowledge this post if helpful.  Thanks- Ed
Posted on Mar 23, 2010
Need manual for self cleaning, please?
Hello Mary;
You can get a user manual at the following website.
Locate your oven model number. It is located on a label either on the face of the oven when you open the door or on the side of the door. Put he model number into the website and you will get diagrams, component part numbers and manuals.
http://www.searspastsdirect.com/
I suspect the user manual is not going to help you. Tell me the model number and what is going on.
Manufacturers offer the self cleaning feature on ovens because customers like this feature and the ovens sell. Yet, the manufacturers engineers have not been able to provide a design that will protect all of the components from self cleaning temperature of 900-1,000 degree F.
When you go into the self cleaning model, the door will lock when you reach 500-550 Degree F. The oven temperature will raise to 900-1,000 degrees F. The oven door will not open until the oven temperature drops to 500 degree F after the self cleaning cycle is completed.
Now, You have a high temperature limit switch in your oven. If this switch fails, you will loose power to your control board and you will not be able to open the oven door.
If you have never used your self cleaning feature, the high temperature limit switch may have failed.
Do to the problems involved with the self cleaning feature, knocking out the control board from heat, additional heating element failure, and other components; It is in my professional recommendation as well as my fellow technicians not to use the self cleaning feature. If you do, do not run it for more than 1 hour instead for the manual 4 hours.
Mar 14, 2016 | Ovens
I have a New World Double oven, dual fuel range cooker - NW 90DFD0 The main oven isn't heating up.
Hello Ally;
My name is Peter. I am a retired field service appliance technician.
You may not have a problem. Normally your oven will rise about 40 degrees F. above the set temperature and then shut down, until the oven temperature falls 40 degrees F. below the set temperature, then the oven turns back on.
Your oven temperature is controlled by you oven thermocouple.
You also have a high temperature limit switch, which turns the fan on when you go too far above the set temperature to vent the oven. This may be bad.
Mar 10, 2016 | Ovens
Oven temperature on Neff 195305317 circotherm oven
hi remember that electric can kill you even if it is unplugged, if you don't know what components are likely to hold charge or have large inductance get someone else to fix it.
you need to get the service manual as tis will have fault finding charts, part numbers, location of sensors etc. If you can't get manual then:
Not likely to be temp limiter as this cuts out if temp is too hot. Find temp probe, may be ntc, mercury vapour switch etc. take probe out disconnect leads and measure resistance, heat, or cool, probe measure resistance if not significantly different (ie 10k to 100k or 100k to 300k) then probe is shot. Take probe to spares place, get replacement and refit. Be very careful to refit leads exactly as they came out, don't want insulation to melt and oven to become live. test with oven or meat thermometer as new sensor may need calibration. Should be accurate to within 10C or so
hope this helps
Nov 10, 2012 | Neff Ovens
NEED TO WIRE A OIL FURNACE FAN FOR LOW SPEED IN HEAT AND HIGH SPEED IN COOL
Okay, I've got an answer for you.
If you get a Fan Control Relay that is DPDT, I think you can wire the Low Speed of a two-speed motor to the first N.O. contact, for Heat.
When the Relay trips, the N.O. contact will close, and the fan will run on low.
If it's a two-speed fan, these fans have two windings, the first for low, the second for medium, and both for High.
Wire both windings to the N.C. contact on the second half of the relay.
That way when the temperature drops below your setpoint, both fan windings will be energized and the fan will go nuts.
Of course, this means the fan will NEVER shut off.
And I still don't know why you need high speed in the Cool setting, when your thermostat isn't kicking the Relay.
Oct 10, 2012 | Honeywell R8285B1038 40 VA Fan Center with...
Were is located the thermostate
The thermostat is solid state, it is incorporated into the control board. You can however locate the temperature probe which goes into the left side of the back of the control board and goes into the top of the oven under a cover near the air pressure switch and high limit thermostat. To locate follow the small aluminum tube coming from your exhaust stack, that will lead you to the air switch which is next to where the temperature probe enters the heat exchanger compartment.
Oct 07, 2010 | Baxter BXA2G Stainless Steel Gas Single...
F2 low temp
The most common probem is burned wires going to the heater on the top of the oven cavity. Typically you will see the coating on the wire close to the heater all cracked and bare. You can usually just cut the wire back an inch and pull some slack up and reconnect the wire and you will be good. In some cases the wire will be burned to much and the whole wire will need to be changed. Any oven repair shop will sell you these high temp wires. DO NOT use regular wires they MUST be high temp rated.
Here is some other things to check if the heater wires look good.
COMPONENTS
IR Element
The IR element - a dual coil type heater - is located
in the bottom of the oven cavity. The first coil is the
heating coil. The second is the IR thermocouple
wire. The heating coil outputs 3000 watts at 208
VAC. The heating coil's resistance is 14.4 ohms at
room temperature.
The thermocouple coil is a Type K thermocouple
with a resistance of approximately 20 ohms at the
splices located approximately 6 inches from the
heater and 40 ohms measured at the extension wires
at the I/O control board.
The IR element is controlled via the K5 solid state
relay and the IR thermocouple via the I/O control
board.
Also try this
1. Verify the high-limit thermostat is not tripped.
o If high-limit is tripped, reset and allow the oven to warm up.
o If high-limit is not tripped, follow the instructions below.
High-limit thermostat is not tripped.
Place a small water load in a microwave/heat-resistant container
(approx. 275 ml) in the oven and place the oven in TEST MODE. Press
the MGTRON key to actuate the microwave. While holding down the
MGTRON key, watch the CC and IR temperatures. If either temperature
bounces substantially, there may be a noise (EMI) problem.
To correct this problem, examine the wire routing for each
thermocouple wire. If the wires are routed near any high voltage
components such as the magnetron or high voltage transformers, reroute
the wires. If this does not correct the problem, verify that both
magnetrons are securely mounted.
Good Luck
May 20, 2010 | TurboChef TORNADO Electric Oven
if you open the oven door all the way, then, look under the control panel (where the top of the oven door seats) you will see a plate that has 6 to 8 screws holding it in place.Remove the screws of that plate with a phillips screwdriver.You will possibly need a flashlight to look inside the space where the reset switch is located... but it is THERE. Make SURE that you TURN OFF the circuit breaker or... UNPLUG the range... B4 you proceed to reset. Look for the Red Button on the back side of one of the limit control switches. Press it in till it clicks. (sometimes you'll hear it... sometimes you wont). Plug baack in ro reset your breaker switch, Turn on your oven and see if it works. If it does... then replace the vent plate close your oven door and now your cook"n with gas...well... electricity really.
May 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
Ovens conveyor belt is working, but the heat and air are not working
A conveyor belt oven would make things so much easier for the staff of a pizza restaurant . Is it possible to get a wood fired conveyor belt oven? If not .... could I build one?
http://www.cookbookclub.net/breakfast/breakfast-home.php
Apr 18, 2010 | Lincoln Conveyor Oven - 1130-000-A
I have a lincoln impeger pizza oven and it wont come on
The oven temp high limit is on the back. Depending on model there is a control box high limit that you need to open the control box and locate. If this is the case, make sure the cooling fans are running.
Dec 13, 2008 | Lincoln Conveyor Oven - 1133-000-A
How to remove the control panel on Whirlpool double oven Model RBD305PDS14
Remove the doors by turning toward you a little toggle apparatus located on each hinge. Locate a small screw on the lower inside edge of the left and right hand trim and then slide off the trim. Remove the lower trim then raise the upper trip and put the left end of the panel inside the top opening. This allows you access to the control panel. Test both the keypad part #8300440 and the control panel part #830219 to see which one needs to be replaced. Order the replacement part, plug it in, reverse the precess above and it should work like new..
Oct 02, 2008 | Whirlpool RBD305PDS Electric Double Oven
Dacor ECS130 Epicure Electric Single Oven Logo
333 people viewed this question
Top Dacor Ovens Experts
Paul Bade
Vincent G
Vincent G
ray gallant
Are you a Dacor Oven Expert? Answer questions, earn points and help others
