Try this
Microsoft Windows 95, 98, ME syntaxFormats a disk for use with MS-DOS.
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
/V[:label]
Specifies the volume label.
/Q
Performs a quick format.
/F:size
Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88).
/B
Allocates space on the formatted disk for system files.
/S
Copies system files to the formatted disk.
/T:tracks
Specifies the number of tracks per disk side.
/N:sectors
Specifies the number of sectors per track.
/1
Formats a single side of a floppy disk.
/4
Formats a 5.25-inch 360K floppy disk in a high-density drive.
/8
Formats eight sectors per track.
/C
Tests clusters that are currently marked "bad."
Microsoft Windows 2000 and Windows XP syntaxFormats a disk for use with Windows 2000.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume
Specifies the drive letter (followed by a colon), mount point, or volume name.
/FS:filesystem
Specifies the type of the file system (FAT, FAT32, or NTFS).
/V:label
/Q
/C
Files created on the new volume will be compressed by default.
/X
Forces the volume to dismount first if necessary. All opened handles to the volume would no longer be valid.
/A:size
Overrides the default allocation unit size. Default settings are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes). Note that the FAT and FAT32 files systems impose the below restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526 FAT32: 65526 < Number of clusters < 268435446
Format
will immediately stop processing if it decides that the above
requirements cannot be met using the specified cluster size.
NTFS compression is not supported for allocation unit sizes above 4096.
/F:size
Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8).
/T:tracks
/N:sectors
/1
/4
/8
Microsoft Windows 2000 and Windows XP recovery console syntaxFormats a disk for use with Windows 2000.
format [drive:] [/q] [/fs:file-system]
drive:
Specifies the drive to format.
/q
/fs:file-system
Specifies the file system to use (FAT, FAT32, or NTFS)
Examples
When using the format command, remember all information on the drive you wish to format will be completely erased.
format a:Would
erase all the contents off a disk. Commonly used on a diskette that has
not been formatted or on a diskette you wish to erase.
format a: /qQuickly erases all the contents of a floppy diskette. Commonly used to quickly erase all information on the diskette.
format c:This would erase
all the contents of your C:
hard disk drive.
In other words, unless you wish to erase all your computer's
information, this command should not be done unless you're planning to
start over.
Or
Right click My Computer-->Manage-->then go to Disk Management
and select the to format right-click it and click format. Thats it Your drive will format and You can also choose in which file system you want to format your drive.
For further help or to thank me mail me on my email
[email protected]
