Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My whirlpool ultimate care 2 stops in mid cycle
Washer stops mid cycle and will start again when u beat on the lid in a certain spot. what is wrong?
Posted by jordanslayde on
steve
  • Whirlpool Master
  • 3,361 Answers
Replace the lid switch.
Posted on Mar 23, 2010
Levi Holiday
    Scholar:
  • 68 Answers
Check to make sure the screws on your lid are tight. then on the right side of you washer, push the tub to the far right rear and reach in between the top of the machine and the tub. move the lid back and forth a bit and you should feel a steel rod moving. that rod may need to be slightly bent back to activate you lidswitch fully. also be sure that you lid is kind of domed oup, if you put stuff on top of your washer the lid can cave in a cause you lidswitch to only partially engage and with a little vibration it can disengage tikll you bang on it
Everytime I start the washer it pauses halfway through the cycle why is that
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
Sep 28, 2016 | Washing Machines
Washer gives off hot smell and won't finish a cycle
thanks..then it's the board, not the guts of the system
Mar 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water starts to pass through but then stops and error alarms start
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Oct 05, 2012 | LG Washing Machines
The water starts to come through then just stops and then alarms go off
Oct 05, 2012 | LG WFT1071TP Top Load Washer
Washer stops during rinse cycle and beeps at me
Oct 02, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Hoover six 1100 stops at certain points during the cycle until i turn the dial to skip to next part of cycle?
Sep 25, 2012 | Washing Machines
Whirlpool commercial washer stopped running mid
Most likely the pump is plugged with lint, pillow stuffing, a small object, or some other obstruction which is not allowing the motor to turn.
Oct 29, 2009 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
758 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
