I ran my jato 3.3 into the water. I dried it out, and now i'm having problems controlling the car, seems like it gets too far out of range just being ten or fifteen feet away from my. How do i fix my receiver? I have dried it out, is it a dud?
X Type Transmission is Jato JF506E But, as far as I know transfer case are sealed, you need to replace the transfer case, I have the same problem and I searching for an used transfer case, they cost around $750+shipping in USA search in http://www.usedtransfercase.com/
No there is not a reset button on diswashers. I would suggest you take the heating element out and check it with an ohmmeter to see if that is the problem - which is the most probable cause. If it is open - infinity reading on the ohmmeter, then it is bad.
If it is good then, it would be the control board.
DEAR FRIEND-IT SOUNDS TO ME THAT IMMOBILISER MODULE GOT WET AND IS PREVENTING THE CODE TO BE ACCEPTED,THERE FOR YOUR VEHICLE WILL NOT START,YOU WILL HAVE TO BYPASS THE IMMOBILISER,FOR THE VEHICLE TO START,YOU CAN TRY TO HOLD BOTH BUTTONS IN TILL YOU HEAR A BLEEP SOUND FROM THE VEHICLE,THAT SHOULD RESET THE ALARM,IF NOT THEN THE BOX IS DAMAGED.REPLACE THE BOX AND GET ALL OTHER COMPONENTS DRY.
Are you using the high wash temp setting? I was having the same problem with my dishwasher while using that setting. Apparently, it will run until the temp gets to its required number. And my hot water heater was set to not go that far. So my dishwasher would run and run. I fixed it by not using that setting any more.
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
Does this unit run for hours with 1 min remaining? if so you need to replace the controll board. I have soldered some with sucess but it "Should be replaced" You also need to make sure you have just dry liquid in the unit and "Don't use soap tabs" 1 -3 tsp of soap that is all. If you are good with mech work I can walk you through the way to check ths unit out to tell what the problem is.....
