The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use.
TekColor
Description
Automatic
Applies the best color correction to each graphic element: text, artwork, and photographs
Office Color
sRGB Display: Approximates the colors on a computer display.
sRGB Vivid: Produces brighter, more saturated colors than sRGB Display.
Press Match
SWOP Press: Matches specifications for Web Offset Publications.
Euroscale: Matches Fogra glossy paper specification.
Commercial: Approximates U.S. commercial press target.
SNAP Press: Matches specifications for Newsprint Advertising Production.
None
Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer.
Black & White
Converts all colors to shades of gray
From the workstation, select the color correction in a supported driver.
Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS):
NOTE: Some of the color corrections are grouped under Office Color or Press Match.
- Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed.
- Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed.
- Click on the [TekColor] tab.
- Select the required color correction.
Apple Macintosh OS 9.x:
- Click on [General], and then select [TekColor] from the pull-down menu.
Apple Macintosh OS X, (version 10.2 and higher):
- Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu.
