Question about Fisher and Paykel Fisher & Paykel Washer
I have a smartdrive 601 that will not fill start
I have a smartdrive 601 that will not fill, start wash cycle and after a while it starts beeping and the hot and cold temperature lights flash at me.
  • Anonymous Mar 23, 2010
    Sorry should have said it has been working fine for years and has only now just started doing this. Don't use the hot wash at all.
Dan Webster
  • Fisher and P... Master
  • 8,220 Answers
Posted on Mar 22, 2010
  • Dan Webster
    Dan Webster Mar 23, 2010
    The controls are cooled by the cold water flowing through it. If their seems to be a trickle there due to a clogged water valve it might be getting a bit hot mate and acting weird. Check the inlet screens is what I would do. and make sure didn't have too many clothes in there as you may know she don't like too many clothes or too much detergent.
My F&P Smartdrive 9 Excellence 5.5 GW509R will not start water fill.
no power to turn on the tap solenoid
could be a problem water lever control or program board
call in a technician for a proper diagnosis and quote
Aug 14, 2016 | Washing Machines
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
Fisher paykel smartdrive 601
I can talk you through diagnostics if you want to go on live chat cheers
Mar 13, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Mar 12, 2008 | Washing Machines
Washing Machines Logo
961 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
