Question about Sony Xplod XM-554ZR Car Audio Amplifier
I purchase sony cdx-gt49um but very low bass & av. sound qulity what can i do to improve?
Posted by pcshekhar740 on
Anonymous
    New Friend:
  • 52 Answers
Nothing sony is a good name but when it comes to car audio they have nothing but their name. I had a thump amp from the 80's that worked better than my sony xplod that had more power. If you want better quality try rockford fosgate, clarion or kenwood
Posted on Mar 24, 2010
I have a TNT 115 S that is distorting when i play E string on my bass. What might be causing that?
Please add more information to improve help, does the amp just distorts in that particular note or teh entire sound is distorted? does the amp distorts at low volumes?
Everything works fine but i cant get any sound out of my amp/subwoofer please help spent alot of cash on amp and sub and i want bass!!!
Check the fuse on the main power wire.
Make sure you have a remote turn on wire ran from the radio (blue/white wire).
Make your own ground for the amp using self taping screws....DO NOT USE SEAT BELT BOLTS
HI there, I'm installing the sony explode deck in my car to an amp, and then two speakers, I can't seem to get anything but bass....frustrated...
Its your settings on the amp. There is a noise filter to set it for bass or for high. Just move the switch. If it is set right turn the lph and vph the opposite way the it currently sits. That should fix your problem. If it doesn't check your stereo. If you have it ran through av cables to the back of the system it most likely has a bass filter built in. You have to get the high input wire clip and run it that way.
1helpful
Poor sound
Sit low Bass @+3 / [email protected] 0 / Hi+10
Add SubWoofer with separate Amp and use low pass filter @78hz cuttoff.
It's a cheap unit -don't expect High Fidelity & a warm EQ<
Bass
davey32- O.k,it sounds like you are running subs,this happens if you have the wrong remote wire.You will have power to your amp,when the radio is on.You have to switch your remote lead,to the other blue wire.Try this and let me know I can help. cooltek Mar18/08
1helpful
Sony xplod cdx s11
press Sel until you get on display "Low" adjust level with volume keys + and -....
jgospodaric
Sony cdx mp70
It may be that the remote lead on the amp has been connected to the auto antenna lead on the radio instead of the amp remote lead and because the auto antenna goes down when the cd is inserted it is turning off you amplifier, check the connections behind the radio or if there is a light on the amp check if the light goes out when you insert a cd
2answers
Re: Stereo cutting out
try this: turn it off. spin the volume control back and forth, nearly full range of motion, very rapidly and for a long time (about 3 minutes). repeat for bass control. try stereo. any improvement? if so, what you just accomplished was to wipe the dust off the potentiometer's electrical contacts.
2answers
Amp goes to protect mode only on cd play
Do you get adequate bass on the radio, or is it a bit quiet on the low-end?
Sony Xplod XM-554ZR Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
