Philips hometheatre system HTS3555 stoped working
I have a Philips home theatre system Model HTS3555. I Accidently switched off the HTS while upgrades was in progress.Now my HTS is not working ...its kindof Hanged up ...how to fix this problem
Posted by mapulvohra on
Paul Hutchinson
  • 909 Answers
Upgrade again with the HTS turned on.
Posted on Mar 22, 2010
Philips hts6600 remote stoped functioning
Did you get any answer as i faced same problem... and it's hard to find out how to fiw or even replace it
Sep 20, 2012 | Philips HTS 6600/12 Home Theatre...
Tip
Philips HTS3555 Manual Download
Download Philips HTS3555 Manual
Have you misplaced your Philips HTS3555 Owners Manual?
Would you like a digital, searchable, pdf version of the Philips HTS3555 Users Guide?
Follow this link (& click FREE) to download a pdf version of the Philips HTS3555 instructions.
I hope that helps.
_______________________________________________
on May 13, 2010 | Philips HTS-3555 System
Can I connect a blu-ray player to the hometheatre system?
Technically, yes but not so it would yield BD-quality audio or video. You need a control receiver that accepts either HDMI/DVI INPUT for 720I and above video. The digital audio in will probably suffice.
Jun 14, 2010 | Philips HTS-3555 System
Corrupted Firmware on Philips HTS3555 Home Theatre System
Only posibility is finding a service shop that services Philips....
Mar 23, 2010 | Philips HTS3544/37 Theater System
Philips HTS3555 custom settings reset to factory on its own
this happens when the electricity is fully discharged
May 17, 2009 | Philips HTS-3555 System
Price //
It costs 182$ at amazon.com. You can see it here : http://www.amazon.com/Philips-HTS3555-Theater-System-Connectivity/dp/B000N5ZARK
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Apr 03, 2009 | Philips HTS-3555 System
Dont turn off (HTS3555)
Same thing happened to mine. I called customer support and got it fixed. Unplug the DVD player for 30 seconds. Hold in the open/close button while you plug back in. Keep holding the open/close button and it will open in about 5 seconds. It is some kind of reset code from overheating.
Jan 25, 2009 | Philips HTS-3555 System
Region Unlock code for Philips HTS 3152
Thanks dude,
Not sure which trick worked, but i did ur classic 7,3,4,4,6,6,0 trick, got no message from the player. So i did pressed 0000 after that. Still no message appeared. But when i pressed start....it worked!!!!!!
Thanks a ton!!!!!!!!!!!!!!!!!!!!!!!!!!!!! God Bless...
Sep 23, 2008 | Philips HTS3450 System
Trying to play hddvd onhdmi player
i don't think this model plays hddvd you will need a seperate player for these discs.
you can only play normal dvds not HDDVDs
good luck
smeags
Dec 31, 2007 | Philips HTS-3555 System
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
Televison & Video Logo
487 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
