Question about Biostar TA790GX Motherboard
Led d1 and led d2 lights are off. I have double and tripled check to make sure the cpu was correctly installed. I have the 4 ph lights on but the led d1 and d2 lights blink on and turn off. Any ideas
Posted by onidiablo on
Anonymous
    New Friend:
I had same problem and i turned the power led around and it fixed mine and made sure the connectors are on the right post sounds like you may have missed it by one
Posted on Mar 23, 2010
I noticed it was 2 red lights inside the amplifier, what does it mean?
The amp has 7 LED's in total 4 whiteLED's provide back lighting
the bi-colour LED white/ amber is the power/standby indicator (amber when amp is in standby mode)
The two red LED's are on the Phono Board and form part of the phono amplification circuit.( D1 & D2)They are NOT fault indicators and should be lit during normal operation.
Mar 01, 2014 | Harman Kardon Harman HK 990 Amplifier
I have 9 wire from my front of my case &2line USB in the names are SHIELD/GROUND1/GROUND2/-D1/-D2/+D1/+D2/ +5V1/+5V2 & Ihave 9 socket on my mainboard IWILL P4S from plug in the wires there are...
Refer to the drawing below and I will explain the connections. You have the nine wires as you described. First, you will not be connecting the SHIELD to anything, so set it aside. Now, the remaining 8 wires are split into 2 groups of four. You have +5V1, -D1, +D1, +GROUND1 on the first group. These wires will attach to the ODD pins 1,3,5,7 respectively (see the chart next to the drawing). Use the missing pin location to orient yourself to the EVEN and ODD pins. The remaining wires +5V2, -D2, +D2, and GROUND2 will go on the EVEN pins 2,4,6,8 respectively.
qzlvgaaaabjru5erkjggg==
Hope this helps!
Jan 07, 2012 | Computers & Internet
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
September 6, 2009 to March 24, 2010 is 70% of what date in the future? Thanks......
D1 is the first date given D2 is the second date given Df is the future date Dt is today's date expression is then---- D2 - D1 = 70%(Df - Dt) Solve for Df and get Df = Dt + (D2 - D1)/.7
Mar 25, 2010 | Air Tools & Compressors
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
Just installed motherboard and processor powers up led is on top 4 and botom 2 what does thst mean?
not sure what your asking but if the wrong lights are staying or or not coming on it is because you placed the LEDs on incorrectly. check your manual for the configuration and verify that when you place the connector to the board you have the polarity correct. LEDs are polarized and the electricity can only go one way to make them operate correctly
Feb 11, 2010 | Biostar TA790GX A3+ Motherboard w/ AMD...
Has anyone got the codes for starview box please im stuck!!
CW Keys 5C01 updated 08/10/09 10:35
00= C5 BE AF 36 0A 61 91 AA
01= D2 D1 80 FA 21 85 0F 53
TW Keys 5A01 updated 08/10/09 10:35
00= 83 5D 12 B8 96 F6 1F C4
01= D2 F9 35 22 0C A7 D6 C9
NTL Keys 5401 updated 08/10/09 10:35
00= F0 0E 91 E0 2D C1 C5 FD
01= 5D 61 B2 C8 E7 DD F9 57
Oct 08, 2009 | Intel CPU
Usb connection order PLZ HELP
You should have told me you are missing a manual. If you dont follow thing from it correctly, you can really burn your motherboard. from the usb connectors on the motherboard
you see pins like this 1 is set 1 and 2 is set 2. you see those are wrapped in sets from you cable near the end. dont mix them
ooooo 12345
oooo 6789
lets put it this way
vcc1 = 1
-d1 = 2
+d1 = 3
GND1 = 4
nothing on 5
vcc2 = 6
-d2 = 7
+d2 = 8
GND2 = 9
May 12, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Biostar TA790GX  Motherboard Logo
671 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
Lee Hodgson
Lee Hodgson
Davit Mamyan
Davit Mamyan
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
