I'm using a steam vac for the first time, i wanted to know if the bottom piece that you empty out the dirty water has to have water in to use it. or is it suppose to be empty?it's an upright hoover steamvac for heavy traffic areas and spot cleaning
ITS THE DUCT PIECE ON THE FRONT OF THE DIRTY WATER TANK (DWT). ITS NOT LINED UP. 1. TAKE LID OFF OF DWT 2. SLIDE THE LITTLE SQUARE PIECE (5'X5'X1) (THE DUCT) ON THE FRONT OF THE DWT AS FAR UP AS POSSIBLE AND IF IT BENDS FORWARD FROM THE TOP, DO THAT TOO (SOME MODELS OPEN LIKE A DOOR TOP DOWN, OTHERS JUST SLIDE UP AND OUT COMPLETELY) 3. SLIDE THAT DUCT BACK DOWN AS FAR DOWN AND BACK AS IT WILL GO. 4. PUT THE LID BACK ON BY HINGING THE FRONT LATCHES ON AND THEN SNAPPING THE BACK SIDE DOWN. 5. CHECK TO SEE IF THAT DUCT PIECE ON THE FRONT IS LOOSE BY PUSHING ON IT AND SEEING IF IT MOVES UP AND DOWN. IF IT IS, THE LID ISNT COMPLETELY ON, GO BACK TO STEP 4. IF THE DUCT IS SNUG, CONGRATS YOU SHOULD HAVE JUST MADE YOUR STEAM VAC **** UP THE WATER AGAIN.
The most common reason for lack of pick up is that the lid is not fully seated on the dirty water tank. Be sure to hook the two tabs on the front of the lid, and then snap the rear latch into place. Another reason is that the duct on the front of the dirty water tank is missing. The duct may have been removed to install the hose, and was not put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. On new models the duct tilts forward and cannot be removed. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood.
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty. if the problem persists take it to service.
The only reason for no pick up is an air leak. The most likely problem is that the lid is not properly seated on the dirty water tank. A less common problem is that the round rubber seal the tank sits on is out of place.
hi yuo should be able to pull off the front cover and fill it up with the solution and water then you pour it in the front on bottom after you take out the plastic front you will see the place to pour it. then the piece you pulled out will fill up with the dirty water and simply pull out and empty
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
