Check the center of the impeller, it should be flat on one side round on three, the impeller might be rounded out from the shaft it sits on. You might just need a new impeller. Good Luck, N let me know Thanks. jimmy
Testimonial: "Unfortunately, the impeller is not sold separately from the motor. I'll spend the $59.00. Lot less than a service call. Thanks James2good."
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Unfortunatly, the impeller is not sold seperately from the complete unit. Am going to get the unit for $59.00. Much less than a service call. Thanks james2good.
