The manual of the DVD doesn't say much for models, say's sony HDD, sony DVD, so maybe it's not compatible. Do you have a memory stick for the handycam ? If you stored the video on the internal storage, check the manual to see if you can move it to the memory stick, then put the stick into the DVD player. Or you will need a PC to transfer it with USB, then get a memory stick and put all the video on in and not internal storage, if the DVD is not compatible with the handycam.
HAD the same problem! Called sony and it was fixed for me. I had a/v wires hooked up from my camcorder and from my vhs. I could see the video on the DVDirect screen. I would hit record and screen would go black and say "waiting on input signal". The fix: 1. turn the unit on. 2. Hold the on/off button for 30 SECONDS. (YEP, believe it or not) When I hooked the wires back up and did the same thing I had been doing. IT WORKED!!!! Hope it works for you!
Yes...First chose the appropriate Record Quality based on the total length of all 3 videos you want to transfer. Next using a RCA component cable, connect the Yellow, Red and White from the Hi-8 camcorder to the DVDirect RCA inputs. After each tape has finished, just press the red record button...Press it again when the next tape your want to record begins. When all are done prrss the stop button (small button above the record button) and finalize as normal.
try NERO software...you will be able to go back and forth (pal or ntsc)...this might be a project / but you can also make into a very fun thing....(note also the DVD regions)
There is a firmware update posted on the Sony support web site. It takes care of the copy protect error. However, i have encountered an error where the recorder doesn't identify the input signal. It posts the message "waiting for input signal." I have no solution for this one yet.
