Cell Phones Logo
Question about Nokia Cell Phones
Nokia 6275 charger not supported problem i had changed charging socket and many chargers pls give me a picture solution
Posted by swalehin_93k on
Anonymous
    New Friend:
Nokia 6275 cdma charging nt suported pls give me solution
Posted on Apr 26, 2010
Anonymous
How to repair charging not supported in nokia 6275
Posted on Jul 13, 2012
Charger not supported
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 29, 2012 • Cell Phones
1helpful
When i enter the charger in to my nokia 6275 the the set displyed charger not suported
i think u may changed the battery the orginal battery is replaced by u or ur frnds plesae check it out
7helpful
3answers
Nokia 3110c Charger not supported
First Option:
Second Option:
2helpful
change your charger pin socket.(inside the phone)
3helpful
Nokia 2626 charging not support
First Option:
Secend Option:
1helpful
Please help my nokia 2626 charger not support problem
First Option:
Secend Option:
3helpful
6500 Slide Cellular Phone: charger not supported...
Hai my nokia 3250 was not charging . the display indicates " not charging". plz give solution.
pls check the charger with the some other handset or change the charger and check it if still you facing the same problem you need to change the charger pin
1helpful
Pls somebody help me..my n70 cant charge battery.whats the possible reasons and solutions.?.pls help..
One. The battery is dead. check and change. two. The charger is bust. check and change. If the phone runs on the charger plugged in then charger is fine. three. both one and two. check and change. four. If dropped or thrown around however softly, the charging circuit broken. go to Nokia Care.
15helpful
4answers
NOKIA 6275 CHARGER NOT SUPPORTED
dear,
first of all, is it genuine nokia or chinese nokia. so if its chinese phone then u have to select a specific charger or it can be the charger itself. so check it by changing the same charger. Moreover, u asked about the volume or speaker problem. so, dear, it can be the fault of changed speaker having poor quality or sometimes, it happens due to damage circuitry. check it in depth.
dont hesitate to ask further. brother, im here to help u .
regards,
Jan 04, 2009 • Cell Phones
Top Nokia Cell Phones Experts
Muzahura Frank
Kolbrun...
Marvin
Marvin
